New Smoothflow Pulleys product possibility!
Old Mar 12, 2008 | 01:44 PM
116Fanatic's Avatar
It doesn't add horsepower technically, just frees it up. If you car is using power to pull a 8lb pulley, more power will be free'd up if its using less power to pull a 3lb pulley. Can someone find out if this will fit ALL cobalts?? I'm def interested!
Old Mar 12, 2008 | 02:27 PM
trent_ky's Avatar
you should make a crank pulley and this and sell them together or something
Old Mar 12, 2008 | 03:46 PM
quadracer0387's Avatar
yes, how bout a crank pulley also? im very interested also in the alt pulley
Old Mar 12, 2008 | 05:32 PM
nherbst454's Avatar
Thus far I'm having a heck of a time finding an alternator pulley to get dimensions from. Is anyone out there willing to pull theirs off and send it to me? I'll happily send it back either the same or the next day and give you a free aluminum alternator pulley.
Nate
Old Mar 12, 2008 | 05:42 PM
UmeNNis's Avatar
Nate
Come on guys someone send one! I would send mine if I had to take my belt off anytime soon... I don't though and I need the car for work (17 mile one way commute )
Old Mar 12, 2008 | 06:13 PM
Sufu's Avatar
My cobalt is sitting at the stealership with a toasted clutch. How do you get the alternator pulley off and how soon can you get it back? New clutch goes in next Mon.
Old Mar 12, 2008 | 06:42 PM
nherbst454's Avatar
I'm not certain, but you should be able to break the nut/bolt (whatever holds it on) loose then remove the belt, then remove the nut/bolt and pull off the pulley. If it doesn't want to break loose I've found that using an impact gun works pretty well although you may need to remove the alternator to get an impact gun depending on space.
Nate
Old Mar 12, 2008 | 07:15 PM
Damnit, if it was nicer weather and my streetbike wasnt being flat blacked id send mine, but ill wait tho and be the first in for a set of any pulley you offer once its being produced. :-) Thanks for offering css.net another great product
Old Mar 12, 2008 | 09:22 PM
if i would next day it to you tomorrow, would you next day it back? so i would have it saturday
Old Mar 13, 2008 | 12:46 AM
116Fanatic's Avatar
Daily Driver sorry =\. I wish I could do it...
Old Mar 14, 2008 | 01:19 AM
  #36
116Fanatic's Avatar
Bump for someone to send one in!
This would be a good, well worth it mod if we could get some support!!
Last edited by 116Fanatic; Mar 14, 2008 at 01:19 AM. Reason: Automerged Doublepost
Old Mar 14, 2008 | 01:57 AM
  #37
syP's Avatar
syP
drop me a PM with the address.. and ill send you my pulley.
I got nothing but time.
I didnt even take a look.. are these pressed on, or held on by a nut?
Old Mar 14, 2008 | 02:02 AM
  #38
95cam86roc's Avatar
subscribed.... looking forward to this
Old Mar 14, 2008 | 10:12 AM
  #39
SS/SCking's Avatar
Deff looking forward to this also...
Old Mar 16, 2008 | 08:02 PM
  #40
Infernokron's Avatar
I've got my SS/SC alternator off and sitting in my room. It looks like there's a special tool you need to take the pulley off. Does anyone have any info on this?
Sorry for the bad pic quality. There is a little nut down inside and what looks like a wrench on the top. If you try to unscrew the nut in the bottom the whole middle just spins and the pulley stays still. It looks like there should be something that fits into the big wrench-like opening and onto the nut both at one time. Then you would be able to hold the middle still and just turn the nut. Sorry if that doesn't make much sense...it's hard to explain.
Old Mar 16, 2008 | 08:17 PM
  #41
SS/SCking's Avatar
You need to get a better pic...
Old Mar 16, 2008 | 08:52 PM
  #42
Hope this is better. The nut that is in the center there is a 10mm. I need something that fits into that big opening so I can stop everything except that nut in the middle from turning.
Old Mar 16, 2008 | 08:58 PM
  #43
SS/SCking's Avatar
OK so when you try and turn the gold 10mm nut in the middle the whole pulley spins? If so do you have a strap wrench, bench vice or some thing to hold the pulley?
Old Mar 16, 2008 | 09:23 PM
  #44
The pulley it's self doesn't spin when you try to spin the 10mm nut. The center (silver part) spins with it. I think it's the clutch assembly that's spinning.
Old Mar 16, 2008 | 09:48 PM
  #45
SS/SCking's Avatar
Oh ok for that you just need to stop it with a screw driver. Take a screw driver and wedge it in there so it does not spin... you wont hurt it just break the nut loose and youll be able to hold it with your hand.
Old Mar 16, 2008 | 10:39 PM
  #46
I bent 2 screw drivers so far trying. I don't get enough leverage doing that either. Any other ideas? The nut is on there fairly tight.
Old Mar 16, 2008 | 10:42 PM
  #47
SS/SCking's Avatar
Oh ??? Do you have any thing heaver than a screwdriver like a small prybar?
Old Mar 17, 2008 | 12:01 AM
  #48
nherbst454's Avatar
If anyone happens to have a spare alternator lying around I can give it a shot. With a machine shop full of tools I've got quite a bit of confidence that I can devise a way to remove it. If for some reason I destroy the alternator I would be happy to replace it for you.
Nate
Old Mar 17, 2008 | 12:46 AM
  #49
Ryze's Avatar
Nate, How long would you need it? Less than a day? I am local to you, so i could probably get it to you, but my car is daily driven so as long as I can get the pulley back same day, then I could get it to you
Old Mar 17, 2008 | 02:35 AM
  #50
Avrj123's Avatar
subscribed for more info
