next mod???
Old Aug 10, 2007 | 12:57 PM
braddddddd991's Avatar
next mod???
my mods are listed at the bottom.
what should i get next.i dont want to spend more then 250 bucks?????
Old Aug 10, 2007 | 12:59 PM
BriantheLion26's Avatar
Ingalls or TTR motor mount. Get what power you have to the ground.
quadracer0387's Avatar
2.9
lowering springs
or strut bar brace
blackngold20's Avatar
60lbs injectors and 2.7" pulley
Old Aug 10, 2007 | 01:00 PM
That or get one of nates pullies. Get a 2.9" to add to your stage 2. Ingalls is 150, pulley is 50, I would say that is a good way to spend 200 bucks.
Old Aug 12, 2007 | 05:00 PM
ecotecon18s's Avatar
I've got the 2.85 on mine bro, and that **** pulls like crazy...the weight difference itself between Nates pullies and the Stage 2 is crazy. look into getting short throw shifter...the B&M cuts the distance the shifter moves in half...
Old Aug 12, 2007 | 06:25 PM
Maxim_X's Avatar
How about a progress rear sway and dc front strut bar. Thats the most notable change you will see for your money.
Old Aug 12, 2007 | 07:10 PM
jon_0_3's Avatar
i was gonna say get a 2.85 on it
Old Aug 13, 2007 | 02:13 PM
TurboTechRacing's Avatar
TTR mount and Prothane bushings, or the Progress rear sway bar.
Old Aug 13, 2007 | 02:34 PM
rick1217's Avatar
I say Motor/Trans mounts....if you have money left, buys nates pulley.....
Old Aug 13, 2007 | 02:36 PM
an0malous's Avatar
save your money and get a real exhaust instead of just a muffler
Old Aug 13, 2007 | 06:33 PM
the point
Old Aug 13, 2007 | 06:39 PM
chevysalesman614's Avatar
because just getting a muffler didnt do anything other than make noise... I.E. "rice cannon"
Old Aug 13, 2007 | 06:41 PM
if i got a cat-back it would just be diff pipes though. its basicly a waist. like 5 hp? for 500bucks.. sike
Old Aug 13, 2007 | 10:39 PM
The Corsa cat-back system dyno'd at 12 hp increase FYI
Old Aug 14, 2007 | 12:46 AM
I know was beeing sarcastic..
its just not worth the dough.
Old Aug 14, 2007 | 12:56 AM
tkaugh29's Avatar
with st.2 i think it is, the more power you got the better airflow you need.i would say get traction mods since adding more power isnt doing as much with your stock exhaust. ive heard ingalls is a wicked 200bucks to spend. im loooking into getting that soon.
Old Aug 14, 2007 | 12:57 AM
^^can you feel a difference with your 2.9??
Old Aug 14, 2007 | 10:19 AM
Jimmys2007CobaltSS/C's Avatar
ingalls td, downpipe, smaller pulley, possiblity a tuned
Old Aug 14, 2007 | 11:39 PM
I've got the 2.85 from Nate, and you can def. feel a difference... just the weight difference is crazy. Nate's pulleys are so lightweight, just swapping from the OEM Stage 2 pulley to Nates Stage 2 would probably make a difference (boost up faster)
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
