NGK 4644 1 step gap?
Old Jun 24, 2010 | 11:25 PM
lilhomieb07's Avatar
So i currently have the 6097 1 step which was replaced by the 4644, still the same plugs, but im tryin to figure out what everybody is gapping there plugs to. I think i have mine gapped to .035 wonder if i should go lower or higher. And yes i am modded and tuned if u need to know that to.
Old Jun 25, 2010 | 01:02 AM
SunburstSS's Avatar
wats ur mods budd ? and what kinda tune is it ?
Old Jun 25, 2010 | 09:30 PM
42's, 2.9, 3" exhaust all the way from header back, big bore throttle body, zzp s3 h/e, dualpass endplate. And the tune is Trifecta from Vince himself on teh dyno.
Old Jun 28, 2010 | 12:54 AM
corey_osu10's Avatar
gap to .32
Old Jun 28, 2010 | 12:55 AM
1badBlueberrySC's Avatar
I had my 6097s to .32" for the length of the cars life.... from a 2.85 with meth to a 2.7 with meth...
Old Jun 28, 2010 | 12:57 AM
Caligula's Avatar
Mine are at like 37? Is that bad?
Old Jun 28, 2010 | 12:59 AM
nah it just has a greater chance of spark blow out.... if you are a 2.8 or lower you should be .35 or closer
Old Jun 28, 2010 | 01:36 AM
Dainslaif's Avatar
This.
I think I have mine at .34 but I didn't get around to regapping them after I put the 2.7 on. For your boost level I'd say .34 is good. General rule of thumb is more boost = smaller gap.
Old Jun 29, 2010 | 12:23 AM
So just installed my plugs. I gapped them at .032 and torqued them to 20ft lbs per ngk reccomendations on iron and aluminum block/heads.
Funny thing is i took the old 1 step plugs out and the gap on those were .040 which is stock heat range. I swear i gapped them at .036 last time, so they must of expanded or i just forgot i did them a .040 cuz i didnt read my circle gap tool right.
Anyways the car started smoother, idle awsome, sounds like i have aftermarket cams in my car i think its my magnaflow. I let it idle and looked at my interceptor and no misfires or KR so thats good so far. Guess well see tomorrow when i drive, maybe that explains alil low gas mileage ive had for awhile.
Old Jun 29, 2010 | 12:44 AM
2006superchargedss's Avatar
I think i WILL go to the 0.032 gap as well , currently been .035 with 1 step colder plugs
06MetallicBalt
Jul 20, 2025 08:47 PM
How to Guide
57
Oct 15, 2015 11:56 AM
SSLOW06
Oct 1, 2015 07:21 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
SiloGM
Sep 7, 2015 11:04 PM
