NGK BKR7E iridium equivalent? Or general plug discussion.
Old Jan 28, 2010 | 11:53 AM
Frew's Avatar
Originally Posted by Bika
There is no need to replace copper plugs that often even wtih meth. I have been running atleast 60% meth on my bkr7e's for 25k miles. they still look fine. I will replace them when I bring the car out this spring just because.
unless you are pushing about 400whp, you do not need 2 step colder either.
tell that to my afrs that went from an 11.8-10.6 in three months on 100% meth
John I got a quick question, you go to colder heat ranges to reduce spark blow-out from increased boost pressures correct? So since I will be dropping to a 2.7 but with a ported head, I will have less boost pressure. Should I stay in the one step colder heat range that Im in right now?
Old Jan 28, 2010 | 12:01 PM
Joe Schulte's Avatar
I never said every oil change. I referenced possibly every other oil change, mainly in reference to pulling and at least checking them.
I'd rather just switch to iridium and lose the concerns of doing such.
Old Jan 28, 2010 | 12:02 PM
rnjmur's Avatar
I have been running the BKR7E lately and typically change them out every other oil change (every 12 - 14K miles). When I change them I check them out and by that time the gap has usually opened up about .003 - .004 so they are definitely due at that time. I usually gap my plugs to about ~.037. I ran Iridiums before, but when I switched to a smaller than 3.0 inch pulley the Iridium gap had to be closed alot more so I swapped to copper plugs so I could keep a wider gap.
Old Jan 28, 2010 | 04:17 PM
Bika's Avatar
Fail Less.
idk. maybe you just go through alot more meth than i do.
But i have been checking the plugs at the oil change intervals. they are perfect. My AFR's are always spot-on.
Old Jan 28, 2010 | 04:58 PM
TheSandMan's Avatar
Originally Posted by qwikredline
I pay 14 each for iridium EX plugs. The stock plugs with stock or stage 2 GM last forwever. Push the envelope with TVS or tune or whatever, not a surprise the plug has shorter life...5 k is a little short imho you can find this information here with the search button:
Spark Plug references.
________________________________________
NGK BKR6ES *STOCK heat range* <-- STOCK Plug
NGK BKR6E "V-Power" *STOCK heat range*
NGK BKR6EGP Platinum Plug *STOCK heat range* BKR6EGP NGK G power Platinum alloy stock heat range stock # 7092
NGK PFR6T-10G "Laser" Platinum *STOCK heat range* race plug
NGK BKR6EIX Iridium *STOCK heat range*
Autolite 3922 Copper Plug *One Range Colder*
NGK BK7RE Copper Plug *One Range Colder*
NGK BKR7E Iridium Plug *One Range Colder*
BKR7EIX NGK IRIDIUM one heat range colder stock # 6664 14 BUX Each in Canada
BKR7E NGK REGULAR V POWER? Stock number #6097 says to use 4644
Cheaper $
NGK BKR8E Iridium Plug *Two Ranges Colder*
NGK BKR9E Iridium Plug *Three Ranges Colder*
Denso Iridium IK24 *Two Ranges Colder*
Denso Iridium IK27 *Three Ranges Colder*
Stock Gap is 0.45"
PSi-Fi Pulley Kit Recommendation gap is 0.28"
Intense-Racing GM-MAF-T/42.5lbs Injectors/2.8" Pulley Gap recommendations is 0.45"
South Florida Pulley Headquarters suggested NGK BK7RE gap is 0.35"
For those of you running 2.8" or below. TWO RANGES COLDER IS RECOMMENDED.
http://www.ngk.com/
I purchased the ottp kit a while back and it came with the NGK 1 Step Colder Plugs. Can i upgrade to the two step colder with out a tune? Is it worth it? Last where should I buy them from, because autozone and advanced auto dont carry them?
Old Jan 28, 2010 | 05:15 PM
rnjmur's Avatar
I wouldn't recommend going to two step colder plugs unless the car is strickly a race car, or you are running TVS or a 2.7 or smaller pulley with a very aggressive tune.
Running a spark plug that is too cold will hurt performance just as bad as running a plug that is too hot.
Also, BKR8E are hard to find. you really have to hunt around to find them. Most people that go with a 2 step colder plug usually go with the BKR8EIX which is the Iridium two steps colder and is easier to find.
Old Jan 28, 2010 | 05:23 PM
TheSandMan's Avatar
Thanks a lot for you help, I think im just going to stick with the BK7RE. Anything suggestions on where i should buy them from? I was thinking of just ordering them from Ottp.
Old Jan 29, 2010 | 12:25 AM
I had to buy mine from a local import specialist place, Bap Geon LOL.
They had them in stock, the iridiums I'm unsure of.
Old Jan 29, 2010 | 09:55 AM
qwikredline's Avatar
Good idea all round....
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
Delta coupe
Sep 30, 2015 08:11 AM
grampss
Sep 27, 2015 08:51 PM
