Nitrous
Nitrous
Ive searched and was finding not much. If there is please point me into right direction
This is for my cobalt lsj
I have 2.8 on a stock m62 blower, exhaust, stock he rerouted to the front and option b( will be doing dual pass), e85
Im wondering my options on a 50 shot to make it more fun
Has anyone have positive feedback on doing this? I know the gm s3 kit has the option of running this
Thanks
Thanks
Thanks
Thanks
most people turbo swap because they are not smart enough to build a fast blower car
and you appear to be another
i know you have to piece things together but as far as brands and parts needed. Or if you have a thread already with this info lol ill look at that.
that's what ive read on here but if your going to spray more then a 50 I would recommend using a little race gas like put a couple of gallons to a tank
pm Italianjoe he has run more nitrous then most of us
nx express proton plus is the kit im running it came with everything needed to hook up minus bottle guage or a heater
thank ya. ... your on e85 too ?
These blower cars seem to love a 50 shot.
Makes a huge difference. Nx express claims u don't have to tune for a shot that small. But like mrb sayed it would be way safer the pull some timming out of it
A lot of people have ran a 35 dry shot on a GMS2 setup. 42# injectors and 3.1" pulley untuned. The GM tunes run rich and a small shot won't hurt anything.
The GMS3 pcm is setup for a dry shot. It pulls 6* of timing and adds fuel via the fuel injectors while spraying. The GMS3 tune is way better then the stock and GMS2 tunes.
This thread has a lot of information in it with pictures!
When your baby screams and whines give it the bottle...Nitrous Trifecta GMS3 - Saturn ION RedLine Forums
I run a Trifecta GMS3 PCM which gives me the Nitrous, adjustable Rev Limiter, and 100 octane mode from the GMS3 PCM and the ability to customize the tune using HPTs. Unfortunately, I can not modify the GMS3 specific stuff (I have to rely on Trifecta for that) and Trifecta no longer supports this PCM.
For my GMS3 controls, I am pulling 2* of timing and not adding fuel via the fuel injectors since I am running a wet shot. My firing window is controlled by the PCM and is triggered at > 3750rpms and 100% Throttle.
I am running a wet 35 shot with E85. I don't need to pull 2* of timing but it is the way the PCM is setup from Trifecta and I can't change it. I think I have a version of the tune that doesn't pull timing but using Trifecta's tuning solution is slow and I have not made the time to play with it.
If you are going to run E85, make sure to size your fuel jet approx ~ 30% larger then the calculators recommend.
OP, asks about nitrous, and CSS.net clowns reply with "go turbo"
Going turbo is not the answer for everything power related.
OP, MrB knows his stuff. Also, speak with Tstone, italianjoe1, and ebristol.
All of these guys have experience and will be able to help you.
Next winter, I will be installing my jumper wires and hooking up a nitrous kit on my GMRS3 car. I can't wait.
I am on e85
When you say size it 30% larger meaning? Sorry Im a noob and I been reading up the last few days on this
E85 n20 jets? Can just a regular gas jet work?
Also Im debating on using a wot switch or a window switch
i run a 75 shot of nitrous on my built TVS car
need .003 more for e85 than whats listed for gas
