Normal Operating temps
Old Jul 7, 2010 | 09:05 AM
TotalChaos's Avatar
Being that I leave in the hot of the south...I wanted to see what the difference in engine op temps are out there for stock vs. stage kits vs. just boltons (exhaust, etc.). I owned a Chevy once, V-8, and the thing ran hot around 220 constantly and I did not like that. I live where there is quite a bit of stop and go traffic so I don't want to worry about the car's engine temp fluctuating constantly. All other cars I have owned stay temp wise put no matter how long I sit in traffic. Just curious
Old Jul 7, 2010 | 09:10 AM
BLAZIN07SS's Avatar
I'm too JDM for you
the temp does fluctuate quite a bit. mine went as high as 218* in traffic once but just click on the AC and the temps will drop rapidly. or you can get a tune and your fan settings can be modded like i set mine. anything above 190 gets 100% fan speed. temps drop quick. car usually runs around at 174*
Old Jul 7, 2010 | 09:12 AM
cmatthewb101's Avatar
Mine go up and down all the time in traffic. Highest it was was around 220. Only saw it once though. Although I don't watch them that often
coopercharge's Avatar
My avg operating temperature is in between 180-205. 205 is normally seen while in idle. Make sure to check your fluid and make sure they are topped off dont know if your supercharged or not but make sure to check your H/E fluid that could cause high temps due to createing excess amounts of heat if the air is not properly cooled.
Old Jul 7, 2010 | 09:13 AM
countrySS's Avatar
mine runs bout like blazin and i have exhaust and CAI
Old Jul 7, 2010 | 10:32 AM
TotalChaos's Avatar
It will be supercharged once I get one but doing research now.....Will any of the Stage kits change the fan temp switch setting?
Old Jul 7, 2010 | 10:40 AM
BLAZIN07SS's Avatar
I'm too JDM for you
no. but these motors run hot. if its up at like 240, something is not normal.
Old Jul 7, 2010 | 10:44 AM
The ZZP PCM program will change the fan settings however those are stage kits for the supercharged ss. You can get a tune from a place like Trifecta once you get the supercharger put on and they can alter the fance settings to keep your temps lower.
Old Jul 7, 2010 | 11:52 AM
BLUE TRANSFORMER's Avatar
Down here in florida in the morning The car runs at 174 then in the afternoon it may see 180. I have a stage kit from ottp.
Solaris99
28
Mar 15, 2017 01:22 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
