Not sure which pulley I have.
Old Jun 21, 2010 | 08:54 PM
michelob_ultra's Avatar
It has a polished finish, and it is considerably smaller in circumference than the stock one. lol
I got this car wrecked. I put a 30K mile motor in it which has the s/c and stock pulley already on it. If the motor I pulled out has the smaller polished pulley, i'm assuming that the ecu was modified, but not sure. I'd sure hate to run the stock pulley on this fresher motor with some sort of reflash installed. Might be a touch rich depending on the reflash, but most likely not.
Any ideas fellas?
Old Jun 21, 2010 | 09:01 PM
EcoTecDriver's Avatar
stage II is my guess, measure it, that will tell you.
Old Jun 21, 2010 | 09:12 PM
Oh wait, so the stage 2 pulley isn't supposed to be black in color? I thought they were black from GM. I had no idea they were chrome.
Since the Stage 2 kit comes with injectors and other items, how can I ultimately tell if the car has been completely upgraded to the stage 2 platform? I may end up taking the injectors out of the old motor if it indeed had a stage 2 upgrade. Which point on the pulley should I measure, the peaks or valleys of the pulley grooves?
I'm just hoping that this car hasn't been hacked with mismatched parts and will suck in no time at all.
Old Jun 21, 2010 | 09:15 PM
yea check the injectors they should not be the stock blue green color....
my m62 with the stage II pulley
Old Jun 21, 2010 | 10:47 PM
Blue green as in these?:
They're hella green. lol
So it's as simple as this: If I don't see some hella' green injectors like those in the pic, then there's a mega good chance i'm setting on a stage 2 setup?
Hey, I know Honda's. I've studied GM 4 bangers big time, but it's obvious that i'm still a novice. lol
Old Jun 21, 2010 | 10:50 PM
thedude411's Avatar
ya if those are black ur stage 2. or possibly other another stage kit. is ur pulley 4 bolt or 5 bolt
Old Jun 21, 2010 | 11:04 PM
About the 4 or 5 bolt, I can't remember. lol, I just don't recall. I would think it is a 4 bolt like the one shown in the photo above of the s/c. I just can't think of how the blower pulley hub can pick up another bolt hole.
So where the injectors in the pic above are slime green, the stage 2 injectors are black?
Old Jun 21, 2010 | 11:05 PM
So where the injectors in the pic above are boogger green, the stage 2 injectors are black?
the ones pictured are stock yes,
the stage II are black and gray....Stage II pulley is silver and a 4 bolt.
Old Jun 21, 2010 | 11:12 PM
As far as measuring the pulley's i'm dealing with, which point on the pulley should I measure? The peaks or valleys of the pulley grooves?
Is the stage 2 pulley diameter 2.9" or 3"? What is the stock diameter?
Old Jun 21, 2010 | 11:14 PM
The stage 2 pulley diameter is 2.9" or 3"? What is the stock diameter?
From one peak to one valley I think,I dont remember for sure....stage II is 2.9, stock I dont know.
Old Jun 21, 2010 | 11:28 PM
Omega1x's Avatar
Stock is a 3.5 outer diameter, and i think it's a 3.25 inner diameter.
Old Jun 21, 2010 | 11:31 PM
outer as in the top of grooves or are you measuring the rim or lip of the pulley?
Old Jun 21, 2010 | 11:36 PM
Perfect.disguise's Avatar
GM Stage 2 pulley is black and is a 3.06. Stock is 3.35.
Old Jun 21, 2010 | 11:38 PM
[QUOTE=Perfect.disguise;5041693]
my mistake, I measured earlier and forgot already. and never said GM
Old Jun 21, 2010 | 11:41 PM
Omega1x's Avatar
Outer is the lip. And I guess it's 3.35 inner diameter. Like i had said I wasn't 100% sure.
Old Jun 21, 2010 | 11:52 PM
Thankyou to all that have posted thus far in this thread.
Old Jun 22, 2010 | 07:46 AM
So which kit is this? It's supposed to be stage 2, but the pulley is black. Hopefully today I find that the old motor still has the drive belt laying on it, along with the other hub included in the kit.
Old Jun 22, 2010 | 02:09 PM
CobaltSS313's Avatar
That looks like stage 2, based simply off the fact it has the blue bolts which iirc is the only company that uses these color bolts everyone else uses silver, also I have the intense hub and pulley which has a 5 bolt hub, GM's is a 4 bolt design.
Old Jun 22, 2010 | 06:51 PM
Okay, here's the break down of what I have:
-green stock injectors
-chrome 5-bolt blower pulley
lol, so I suppose my deal is stock. The dude that had it before had a mega big intercooler sized heat exchanger behind the front grill opening. It was definitely aftermarket. The water or surge tank was damned near attached to it. All that stuff got smashed in the wreck, so these items were barely distinguishable. What does the stock water tank or reservior look like, and where is it supposed to be located?
See guys, i'm more at the stage of trying to figure out what I have left to work with. The car is damned near driveable. I need to study the crap out of some stock pics to see what needs to be under the hood, etc. It's soooooo close though. Everything's painted, but the small stuff is what hurts.
Old Jun 23, 2010 | 05:13 PM
If you have a 5 bolt blower pulley then its not GM or stock, stock pulley was pressed on with no bolts and GMs pulley has 4 bolts
Old Jun 23, 2010 | 05:20 PM
Bl4des's Avatar
take the pulley off and look at the back side of it it should have what size it is stamped on it
Old Jun 23, 2010 | 07:44 PM
Oh so if I don't have the factory pulley, and have stock injectors, there's a good chance the previous owner slapped on a small pulley and let'ur rip.
Is there a reflash available for these cars that doesn't require changing injectors? This will give me some idea of whether the pcm has been reflashed or not. The stock light-green colored injectors are there. The previous owner also used to have a huge front mount heat exchanger.
Old Jun 23, 2010 | 07:45 PM
Pedobear's Avatar
@ the OP
Shiner is better :biggrin:
Old Jun 23, 2010 | 07:48 PM
Nighthawk243's Avatar
A 2.9 is smaller than GM Stage 2 by a small amount. Probably an OTTP or ZZP pulley and hub.
Old Jun 23, 2010 | 08:04 PM
Originally Posted by Pedobear
@ the OP
I don't get it. lol, what's "Shiner?"
The only thing that bugs me is that I still have the stock injectors. Is there a reflash available that would compensate enough while using the stock injectors with a smaller blower pulley?
This would tell me whether the previous owner just slapped on a pulley and did nothing else.
Last edited by michelob_ultra; Jun 23, 2010 at 08:04 PM. Reason: Automerged Doublepost
