O2 sensor???
Old May 20, 2012 | 12:23 AM
yellow06's Avatar
O2 sensor???
Ok, so i bought a zzp catless downpipe with an angled o2 bung, but, my problem is that i can't remove the o2 sensor from the stock downpipe, I've tried quite a few things to get it off,but I have had no luck! Unfortunately I've practically stripped it now so I was wondering if you guys know how much a replacement from gm would cost or if there is a cheaper alternative?
Old May 20, 2012 | 01:09 AM
bluebalt07's Avatar
Autozone carries Bosch sensors for around 80 bucks so I'm sure one from gm would cost at least 120. Also, did you try pb blaster and heat on it with an o2 sensor socket. I know they're still a bitch to get out but that houldve done the trick
Old May 20, 2012 | 01:22 AM
robby1029's Avatar
You need muscles lol
Old May 20, 2012 | 05:08 PM
WalkerTech's Avatar
Yellow,
I am a product specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. It sounds like you may have to get a little creative to remove the old O2. A vice grips may be helpful if there’s room. A large tap and die kit should do the trick if that fails. Regarding replacing the O2, a GM replacement will certainly be expensive. Are we talking about the post cat sensor on a 2.0L? Walker offers a direct fit sensor for this application, part number 250-24354. This sells on Amazon for $46.96.
Old May 20, 2012 | 05:28 PM
Blowncavy's Avatar
I have 2 02 sensors down streams. I didnt need them as in tune I deleted them
Lmk I sell one cheap to you
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
