O6 pulley and injectors
Hello new to the forums and new to the cobalt ss/any 4 cyl. I'm about to buy a 06 ss/sc and it comes with a 2.8 pulley and 60 lbs. Injectors. Will it need to be tuned to run this? I am used to sbe on carb and dizzy where you get straight power without tuning. I choose this car over building a 400-500 hp sbf for my truck.
Hi Mike welcome! If you purchased it with the 2.8" pulley & 60" injectors already on it then more than likely it's already been tuned to the 60" injectors however if I were you I would ask the person your buying it from & if they did say it's been tuned find out where they got it tuned.
JD is correct just make sure that you do not install your new injectors without tuning your pcm to them at the exact same time, as JD mentioned make sure you find someone that knows are cars. If you don't have HP tuners & you need a Quick in expensive tune you can always get ZZPs tune. If you don't live close you could ship them your pcm & they will tune it for you however HP tuners & tuning your car with the pcm is always better than a canned tune but it's always an option
SatanzSS/SC
Apr 24, 2012 09:44 PM
KyFritz06SS
Dec 23, 2010 11:08 PM
Billig ss/sc
May 23, 2008 12:14 AM
xpanterax
Mar 26, 2008 11:37 AM
