Odd RPM pattern
Old Apr 26, 2007 | 06:52 PM
slvrcobaltscss's Avatar
Question Odd RPM pattern
I tried a search and couldn't find anything. Is it normal for the SS/SC to come down in RPMs really slow when revving in neutral? If I just sit there and rev to high RPM's and then get off the throttle completely it seems to take longer than it should to drop in RPM. Also it get's down to around 1800, then goes back up to 2200 on it's own before settling into the normal 800 idle...any info on this would be useful, thanks in advance
Old Apr 26, 2007 | 06:56 PM
Mikey851's Avatar
Well for one thing we don't have high compression engines and if there is no boost present the engine doesn't create alot of pressure to "engine brake" once the throttle is closed.
Also, it may just be the computer adjusting the idle to it's liking when it dips down and then comes back up. Don't worry about it; none of that has any ill effect.
Old Apr 26, 2007 | 06:58 PM
I've just been having major electrical issues with this car and I'm wondering if the ECU isn't completely messed up...thanks for the input though
Old Apr 26, 2007 | 07:09 PM
Formula96's Avatar
2 things.
1. There is a service bullitan for an erratic idle on the 05-06 cars. Just needs to be taken to a dealer and have the ecu reprogrammed. That is if the car falls within their limits.
2. Also, because we have no iac valve in our cars, everytime we drop the throttle, the pcm has to keep the car running by opining and closing the throttle body.
Old Apr 26, 2007 | 07:29 PM
sealy's Avatar
yep...i'm pretty positive it's just the computer dropping it down nicely.
it happens to me too sometime.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Sep 28, 2015 02:46 PM
hhrfreek
Sep 11, 2015 01:28 PM
Builttss
Sep 8, 2015 05:34 PM
