Official catch can/crank case vent system thread
Old Nov 7, 2013 | 10:21 AM
  #226
574's Avatar
574
I hate to admit it but I'm more lost than Helen Keller
Old Nov 7, 2013 | 10:26 AM
  #227
JapEatr's Avatar
South Central *********
the pressure in the manifold is whatever the gauge reads. as the TB opens it equalizes the pressure in the manifold ~19"Hg. against atmospheric pressure (14.71 psia, this is absolute pressure)
Old Nov 7, 2013 | 10:37 AM
  #228
mrbelvedere's Avatar
the gauge is showing 10in vac plus 9psi atmosphere
Old Nov 7, 2013 | 11:33 AM
  #229
Powell Race Parts's Avatar
o mi. some one help Mr. B. At least 574 and I both agree we are lost with logic that adds 1+1 and gets 5.
Old Nov 7, 2013 | 11:38 AM
  #230
ok then when manifold vacuum drops something has to replace the lost vacuum so since you know enlighten us and I don't need any help because I am correct and you and alan are not
Helen keller was never lost
Last edited by mrbelvedere; Nov 7, 2013 at 11:40 AM. Reason: Automerged Doublepost
Old Nov 7, 2013 | 11:44 AM
  #231
SMH. It has been explained to you over and over; Technical information posted. Laws of physics explained. Hard to do more than that.
Old Nov 7, 2013 | 11:55 AM
  #232
armcclure's Avatar
Ok I'm going to make this simple for you.
One question at a time.
The hose on the back of the vc is connected to the intake tube, which is at atmospheric pressure.
The intake manifold is (let's say at cruise) has a vac of 10" as read on the gauge.
The gauge is telling you that the absolute pressure in the IM is 10" below atmospheric
So, how is the crankcase pressure (by your logic) lower than the intake manifold?
Old Nov 7, 2013 | 12:10 PM
  #233
im in the bermuda triangle
Old Nov 7, 2013 | 12:14 PM
  #234
so you don't know what replaces well ill tell you what replaces the lost vacuum atmospheric pressure
Old Nov 7, 2013 | 12:17 PM
  #235
Area47's Avatar
Rent me! per hour
her dog was named mittens.
/thread
Old Nov 7, 2013 | 12:25 PM
  #236
armcclure's Avatar
We do know. And we've told you over and over.
This may be the most correct statement you've made regarding pcv yet.
Yes atmospheric pressure replaces vac.
The manifold pulls a vac on the crankcase (any time your boost gauge reads vac greater than 3kpa, less than 1/2"hg)
This vac is replaced by fresh metered atmospheric air supplied by the rear pcv tube running to the intake tube.
Old Nov 7, 2013 | 12:47 PM
  #237
Ok lets move forward here I just would rather not participate than continue to deal with Mr. B to tell the truth. So whatever JW you post about this particular subject, I promise not to reply.
Old Nov 7, 2013 | 12:51 PM
  #238
InfraRedline's Avatar
/thread
You are thinking of her "cat"
Old Nov 7, 2013 | 03:20 PM
  #239
slitterell's Avatar
Haha it is finally over. It was fun to watch. So, why was the a crucial argument? haha
Old Nov 7, 2013 | 03:57 PM
  #240
cliffnotes would be nice tho
Old Nov 7, 2013 | 04:42 PM
  #241
armcclure's Avatar
It's not over. MrB still thinks witchcraft happens and makes air flow backwards from low to high pressure.
Old Nov 7, 2013 | 04:44 PM
  #242
Area47's Avatar
Rent me! per hour
Old Nov 7, 2013 | 06:06 PM
  #243
BlkWdoSS's Avatar
Get rid of the FAI, **** on the LSJ factory IM, and go turbo, problem solved...
Old Nov 7, 2013 | 06:31 PM
  #244
armcclure's Avatar
I really hope you're joking... Or enjoy popping dipsticks.
FYI turbo swaps using the Saab IM retain identical pcv operation as stock, other than the FAI being unmetered on a blow through setup.
Old Nov 7, 2013 | 07:29 PM
  #245
JapEatr's Avatar
Deleting things is rarely a smart move
Old Nov 7, 2013 | 08:04 PM
  #246
armcclure's Avatar
What?
Nvm. I thought you were saying I deleted something in my post.
Old Nov 7, 2013 | 09:14 PM
  #247
slitterell's Avatar
LOL jackass. He messing with me
Old Nov 8, 2013 | 08:37 AM
  #248
I still don't see where you're finding this magical pressure that defies physics and closes the valve..
I believe it stems from the fact that you (incorrectly) still believe the fresh air inlet is the pcv's primary vac source. It is not. It is a fresh air inlet and the relief passage for blowby gasses when the valve is closed.
FLOW has nothing to do with when the valve opens/closes. It's PRESSURE. one side of the valve is connected to the post tb vac side of the IM. The other is connected to the case/FAI/intake tube (near zero pressure ie atmospheric)
AT ANY TIME THAT MANIFOLD VAC IS MORE THAN 2-3kpa GREATER THAN ATMOSPHERIC PRESSURE THE VALVE IS OPEN.
This is not my "opinion" it is a ******* FACT.
Either way, I have a guy coming over tonight allowing me to run a test on his car, to prove to you once and for all that the valve is open at cruise.
you have less crank case pressure at speed/cruise due to less blow by because things are happening at a much higher speed it has has less time to get past the rings
Old Nov 8, 2013 | 08:43 AM
  #249
Tjolley's Avatar
On a healthy engine that is very true but how many of these guys running around here have hurt engines? My Gess is majority. Were blow by overwhelmes the stock pcv system.
Old Nov 8, 2013 | 09:10 AM
  #250
armcclure's Avatar
So you're claiming that the crankcase (which is open to atmosphere via the pcv tube), at cruising speed, is somehow creating a vacuum (out of nowhere) that is stronger than manifold vac?
