Official GMPP Stage 3 Dyno Session
It's a dynapack chassis dynometer.
http://haddadmotorsports.com/dyno1.htm
Did you guys see the video?
Area47 just out of curiousity what seems scary to you about that AFR? It seems pretty safe to me, but I guess the only way to know for sure would be an EGT gauge.
RoelSS have you pulled a plug to see what it looks like after spraying a few times?
The AFR was 10 flat! horsepower dropped nasty to 174!!
Keep in mind that this a DYNAPACK DYNAMOMETER so there is no rollers like a traditional dyno, the axles actually attach to the DYNAPACK DYNAMOMETER, these type of Dynos are supposed to be the most accurate. Maybe thats why it reads lower than most other members dyno #'s. Take it to the track and run a few passes and then fill us in
If I add a shorty header and a catless downpipe, do you guys think it will hit 290HP?
Also, it would seem MUCH safer if you switched to a wet kit, rather than dry. With that lean of an AFR your asking for a burned piston.
Not that I know of. Anyone else?
ALOT of balt owner's blow there motor cause they dont monitar IAT's.. both 1 and 2.. i had blown piston ring land's in #4 and a blown cat... the guy who bought my RL found out and get everything replaced under warrenty.. it was a stage 2 IRL with BASIC bolt on's.. and after the CAT went the ringland's went to.. boosting 19 PSI on a stage 2 tune isnt possible according to GM.. but i had cell phone vid's of the car doing it at 135+ mph.. after i sold it of course they found the issue.. my car was in the shop for 34day's and no real answer as to why it coudnt go about 5.5k.. and that's a saturn engineer that tore **** down..
What are the levels as far as cool/normal/should prolly watch it/you're about fucked/you are fucked IAT wise?
Thanks guys for answering the questions. I'd like to run S3 pretty soon but want to make sure I have all the info I need first.
Also I plan on not lowering my pulley past the stage 2 level just because most of what I've read on here just doesn't seem like it would be beneficial. And I/E + 50 shot would get me where I want without having to keep pushing the engine all the time.
Update:
Well I have NOT blown anything and the motor is running strong. Currently at about 67k miles and went through plenty of bottles.
No burned Pistons
You need to re-dyno now that your car is working 100%. Wasn't your intercooler pump shot at the time of these tests? Keep me posted on your results!!
