Official Turbo LSJ thread!!!
#2877
Here's your powerband....
Adjustable Powerband - $95.99 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
#2878
Ditch that ol' fookin' tooner!!
#2885
So the car is up and running with the ported head and new pistons but the TOON hates me, LOL. Its super lean and hangs at 2200 rpm while going down the road and takes a long time to get back down to the 900 rpm idle. Getting that fixed soon.
Anyway, the sensor below the fuel rail I found out is the Ambient barometric pressure sensor, dont remove it, I took it off and it threw a P2226 code, guess it tests the outside air BARO to compare to the pressure in the intake. Thought it was a sensor leftover from the supercharger. Nope it needs to stay on there.
Ignore the big chunk of brass and the breather, its temporary. My lines and catch can are in the mail. Going to create a vacuum on the catch can and connect my heavily modified valve cover to the setup in 3 places.
So the MAF and MAP sensors are mounted on my hahn manifold seen below. Why is there 7 degrees between IAT1 vs IAT2 (IAT1 = MAF, IAT2 = MAP) if they are sitting on the same manifold?
#2889
MAP/IAT2 is on the manifold hence why its a good bit warmer than the one after the Intercooler, which MAF/IAT1 stays below 100 generally (even in 90+ texas heat)
What I should have asked was what was the SCIP sensor for since there is no supercharger anymore? Why was it not deleted by hahn? Do you all keep the sensor with your ZZP setups or other turbo kits?
EDIT: I just looked at my old tune when I was on the hahn turbo kit at 15 psi. It was so happy and rarely knocked. My new mods have made that tune obsolete. Its lean and runs like crap... :rolleyes
#2891
I am reading a book called Engine Management Advanced Tuning by Greg Banish in the Performance How-to series of books. I am learing so much about timing, spark, MAF, and generally anything about tuning our cars. Just tonight, I read a few chapters and have been really enjoying it. Now putting into practice is going to take some time but I am babying the car anyway due to ring break-in.
#2893
Sounds awesome but I am packing my home and moving very shortly. I cant right now. I am also logging the car for CCSS3. He has been a big help. There is also this thread that I am going to try if I can figure out how to log LTFT STFT and MAF tables. In my tuning book (bansih) it states that once you get maf correct everything else uses it as a reference so it makes the biggest difference to have it corrected to a turbo car.
#2895
Getting maf tuned right now, logging for ccss3 today.
