Official Turbo LSJ thread!!!
#5026
Rent me! per hour
shamless plug. i have had gm engineers come to me and ask questions about lsj calibrations and how i got things to work.
trying to back over things is fine and dandy, but you're going to end up in the same place.
#5028
I know I am hardheaded but I do things my way first then if they break I tried it my way, I will go back to what is proven and dig deeper. I have always been this way with fabricatiing my own suspension systems for several trucks and jeeps and now trying to get into cars is painstaking slow and the cost is a lot more than I would have thought compared to my 4x4 past.
#5029
Rent me! per hour
Race teams or GM in respect to production cars? Just curious cause that is
im just advising on whats going to happen. i have been in those shoes before, and am stubborn to a fault. when it happens and it will, just smile and go with it.
#5030
the quote was taken out of context sunshine. the basis was behind running over 17psi where the ve table stops. or disabling the ve table all together.
with the dynamic set to an enable of 400 disable of 300, you're not 100% out of the ve map. this becomes very apparent when 98lb injectors are thrown into the mix. but not until that point. so a dynamic disable was given to us for fueling issues in the higher power cars. it wasn't a ve tuning problem, or a maf scaling problem. it was a confused ecm problem. this table eliminated that issue.
#5032
What's up everyone. I have a pte 5431 with a .63 ar pushing 20 psi and was wondering when I should hit full boost? I am curious because I see everyone's videos and it sounds like they don't have a lot of lag and they are just pinning the tires.. I barely spin in second with my all seasons.
#5033
Spinning tires has more to do with the driver than boost lag or "full boost". Remember just cause your not making full boost til later in the rpm range, you are still actively making boost from <1psi all the way to 20psi. I would not want boost to come on like a switch while under acceleration (some like this) but its just stupid on the street. By the time you have run through the gears the race or screwing around on the highway is over. What you want is a linear amount of boost vs rpm. That also comes with a properly sized turbo and AR. Your not going to have to worry about that with the 5431.
#5034
Hey all what if anything should I be concerned with about my turbo once my motor is done. Mainly concerning the oil and any potential debris like metal shavings from the fresh build. Is that gonna get through to the turbo?
#5035
jonnymerk, i can tell you that my oil filter was so dirty that it was restricting oil in the first few hundred miles. When I did the second oil change the oil was pretty black. I feel this is mainly due to oil entering the intercooler pipes from seals going out on my turbo. But the filter had a few tiny flecks of metal in the filter upon further inspection, what you might find after having the head or block milled but nothing major.
Change your oil after a few hundred miles and inspect your filter. My oil pressure was way better and more in line with engine speed. The car was a lot happier after the oil filter and change to 10w30.
#5037
Rebuilt my 20g today. Freaking love this turbo, makes great power, easy rebuild and mine was in awesome shape. I didnt find anything in the wastegate or turbo to make me think there was boost problems but the bearings were beat!!!! The oil seal on the compressor side was also hard as a rock and square, where as its supposed to be soft and round. Definately is going to make a nice difference if the bearings were the culprit of my limited boost. Going to have the CHRA VSR balanced on monday. I am at a work stop for now.
In this pic you can see all the old parts vs the new parts. The bearings are brass and really beat up on the old side. Everything on the new stuff is just pristine.
#5039
looks good. So other then changing the oil out after a few miles etc...you don't think there is any other precautions? I think at most my mechanic got 6 attempted pulls on the dyno after the turbo was put on before he decided that the motor was failing. Once opened we saw sparkles around the crank and rod bearings etc...
#5041
I did nothing but change the oil and get a tune right away. I made the 420hp on the dyno with just 100 miles on the new build. I am at 1000 miles now and the car is running awesome except for these blackened journal bearings. I have had other things that were oil related but got them all taken care of.
edit, in case you ask.
oil in my charge pipe (bad turbo seal, confimred) fixed
oil filter crushed under pressure, fixed
oil pressure low due to filter, fixed
timing tensioner allowing slap due to restricted oil flow, fixed
i run an oil pressure gague, read 40-60 psi with crushed filter runs at 40-100 now
changed oil viscosity to 10w30, car and oil pressure are much happier, pressure is more in line with engine speed
oil pressure low caused the tensioner to allow chain slap and broke a guide bolt, fixed with a 10.9 grade bolt instead of stock 9,8
would have caught it all way earlier but have only had the oil gauge about a month. big help since there is so much riding on the oil sytem with a turbo car
search turbo duck for all the stuff I have been doing to the car, its all well documented.
#5043
not sure what you mean as far as motor failing. Did you destroy your motor?
