Official Turbo LSJ thread!!!
#602
Deep sockets won't bite onto it. The best way I found was to go from the top with an open end. Problem is that I can only get so far before the head gets in the way. It's seriously making me angry.
#603
T3 TO T3 ADAPTER CAST EXTEND FLANGE 35/38MM WASTEGATE | eBay
thats always an option. for adding a wastegate to a non-flanged manifold.
#607
bolt tightening alternate solution
I used custom bolts with hex head thus no socket needed also safety wired all the bolts after having to retighten the original bolts. There is also small head bolts just for this type of application. Check with your local nut and bolt specialty store.
#608
I finally got it all taken care of but thats not a bad idea at all. That was tge biggest pain of this entire install. Lol
#613
I ordered the complete swap kit from zzp No cat, External dump, Bullseye s252 Extended Tip, No injectors( already have 60#), NO tune because im driving it up after install, boost controller and zzp 50mm BOV,
Im going to pick it up on friday at zzp.
Did i mess anything up with my order does it sound correct?
after install, Im selling the LSJ bolt off kit that comes off my car, Anyone interested let me know!
#616
#617
Do you know if theres any welding that needs to be done with the purchase of the zzp turbo swap kit i mentioned? im seeing how everyone welds the oil feed line on their oil pan, does zzp's kit require that or anything like it welding wise?
#618
Car runs fantastic. Had a small problem with the boost controller. I'm only set at 17psi for now. Anything after that and my clutch starts crying. Lol. In my opinion it runs better than it did stock. As for the manifold... I'd rather not talk about it...ever...again. Lol.
#619
the only thing you have to weld is the oil tap fittin in order to run ur oil line from ur turbo to the oil pan. that would be all the welding there can be when it comes to these builds. good luck man, keep us posted. btw if you can get a base map for that 3 hour drive then do so. driving the car with a retarded tune on that setuo for a 3 hour trip sounds like it can mean trouble down later on just saying...
#620
#622
Ill keep everyone posted
#625
