Official TVS Thread!!!
Old Dec 1, 2012 | 10:42 PM
  #3426
Powell Race Parts's Avatar
L61 maybe? ALL lsj are the same.
the only difference with 07 is that powertrain did the ecu calibrations not performance division. say it again armcclure: ALL lsj are the same.
Old Dec 1, 2012 | 10:44 PM
  #3427
RooTBeeR's Avatar
no no no, im sure mine has to be different though!
one shiny rotor?
Old Dec 1, 2012 | 10:52 PM
  #3428
Old Dec 1, 2012 | 11:12 PM
  #3429
armcclure's Avatar
ALL LSJ's ARE THE SAME!!!
I only said maybe l61 because I knew there were a few differences... Frankly I haven't paid much attention to anything but the lsj motor and le5/lnf blocks.
one shiny rotor?
If that's the case you would have much bigger problems to worry about lol
Old Dec 1, 2012 | 11:14 PM
  #3430
RooTBeeR's Avatar
Old Dec 2, 2012 | 04:41 PM
  #3431
383_Stroker's Avatar
I have been. Area and tstone both ran tvs's.
The 79's never seemed to flow what they claim; they fall behind 80's by alot more than 1lb.
Is your fuel system completely stock?
The idle dreamy though.. Yeah, fuel system is completely stock otherwise.
Originally Posted by Melon
R they maxxed due to runnin the e blend?
Yes, they are in the low 70% duty cycle on 93. Upper 90's on the blend
Old Dec 2, 2012 | 05:57 PM
  #3432
100% METH's Avatar
Dustin needs more meff
40% IDC or bust
Old Dec 2, 2012 | 05:58 PM
  #3433
574's Avatar
574
Is there any benefit to meth with E?
Old Dec 2, 2012 | 06:36 PM
  #3434
bratboy90's Avatar
Yes.
Old Dec 2, 2012 | 07:27 PM
  #3435
sjc0013's Avatar
Window Licker
I wanna run E so bad
I know. Cool story.
Old Dec 2, 2012 | 07:59 PM
  #3436
TStone's Avatar
I know. Cool story.
You're not alone :/
Old Dec 2, 2012 | 08:01 PM
  #3437
574's Avatar
574
They don't have E in Ohio??
Old Dec 2, 2012 | 08:04 PM
  #3438
TStone's Avatar
They do, not near me though :/
Old Dec 2, 2012 | 11:00 PM
  #3439
bratboy90's Avatar
I love running on the E.
Old Dec 3, 2012 | 12:14 AM
  #3440
InfraRedline's Avatar
Mainly cooling purposes. In that case you can just run straight distilled water. Some people use meth with E85 as a bandaid to give them more fuel up top if they dont have the fuel system to support it.
Old Dec 3, 2012 | 12:05 PM
  #3441
armcclure's Avatar
I tried straight h2o and it bogged just a hair at low rpm when it kicked in, like at 3k. Running a 20% mix (washer fluid) cured that.
I run it for blower cooling and the boost gain. Too many ppl discount the effect of the w/m tightening up the rotor-case tolerance. I gained 1-1.5 psi midrange spraying 7gph.
Old Dec 3, 2012 | 12:26 PM
  #3442
Vander Nars's Avatar
U was running straight h2o aka water in ur engine? Aint that a bad idea or did u mean pure meth?
Old Dec 3, 2012 | 01:04 PM
  #3443
ThexGovenor's Avatar
I think the water attomizes and uses the heat from the blower to do this. Correct me if Im wrong...
Old Dec 3, 2012 | 01:06 PM
  #3444
Good info Alan. I considered running 3gph or something small of distilled water, but I don't think it would do much for IAT's since before E85 my old 50/50 mix through a 5gph barely made any difference in intake temps.
Old Dec 3, 2012 | 03:06 PM
  #3445
Yes I would discount that statement. I would suspect that the meth mix is doing sfa to the "rotor-case tolerance" I would suggest you are making more power and the back pressure is increasing with the stock exhaust port as you make that power, and the pressure increases.
Think about it.
Old Dec 3, 2012 | 03:10 PM
  #3446
Bluelightning's Avatar
Got Bewst?
Actually John water/meth does tighten up up the rotor tolerences because it doesn't compress and creates more boost.
Old Dec 3, 2012 | 06:38 PM
  #3447
Laser_Blue's Avatar
Ok what about putting in forged pistons, do I need to re-sleeve the cylinders?
Old Dec 3, 2012 | 09:21 PM
  #3448
Got Bewst?
No. But you will need to measure the sleeves to make sure they are straight. If not, you will need to bore them.
Old Dec 3, 2012 | 09:40 PM
  #3449
show me the data. looks good on paper. I am not seeing it. maybe I ask eaton. and ps, the water meth erodes the coating on the rotors. that much i have seen over and over.
Old Dec 3, 2012 | 10:28 PM
  #3450
Got Bewst?
I'm sure 100%METH or Euthanasia will chime in with the data you are wanting.
As for the coating coming off due to meth, here's some informative info
WATER INJECTION FORUM - Can I Spray Water Methanol Injection Through My Eaton Supercharger?
