Official TVS Thread!!!
#7476
afr 11.2 17deg timing maf maxing out 11500htz idc 85% tvs on 2.9 pulley plus ati custom comp cams 50/50 110 race/pump fuel
I only made 4 pulls first pull was 315 added 2deg each pull 3rd pull went 339/256 4th pull added 2 deg no change in hp or tq did not want to push it any harder due to maf maxing
#7478
Did you try leaning it out when you added timing since you are on a race gas blend? Also, there should be no reason you are at that MAF frequency at that power level. What size is your MAF housing? Either way the curve looks really nice and some good solid numbers to kick things off.
#7484
Too many variables on an LSJ. I had stock blower "flowing" 49 lb/min with a raped maf on the 80's, but on the scaled 98's it would flow as low as 28 lb/min.
#7485
Fix your **** John there is no time for non-***** out numbers! jk good baseline runs like I said. Gotta be fun to be back at it again.
#7493
I'm in the same boat, I keep my eyes glued on the afr if I take it all the way to 8 lol, ride out the last cell
I'm looking into a mini afc to fix this
#7497
I discussed that with him as well. Don't be afraid to go into "no man's land" lol he is aware though.
#7499
Same difference as far as the PCM is concerned.
