Oil Change -> Reduced Power -> check Engine -> After I forgot to connect censor
You know you have to disconnect that censor to get to the filter on the LSJ?
My dumb ass forgot to connect the censor after I changed my oil.
Started the car and it ran like ****. Reduced power came on, check engine and stalled. I connected it and disconnected the battery but now my check engine light is still on. What’s the fix?
car needs to go through a few heat up and cool down cycles and u should be ok..it takes a lil bit, but u should be all set. but it does involve driving the car, so go for a ride and just do your normal routine and it should clear itself if everything is good
i find it easier to disconnect the sensor as well... while using the extension it puts pressur on the plastic clip which is brittle already and it cheap insurance to just disconnect and move aside
TurboTechRacing
Oct 27, 2015 07:58 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
