Oil dilema
Old Dec 17, 2008 | 09:22 PM
Int0x's Avatar
Exclamation Oil dilema
I normally use mobil 1 for my oil changes, but I have some royal purple lying around. I was told that I should continue to use mobil 1 because even after draining it, it doesn't mix well with other oils, and I really have no clue. I want to use to the royal purple.
Old Dec 17, 2008 | 09:23 PM
DebadgedBALT77's Avatar
just use it
Old Dec 17, 2008 | 09:24 PM
JimzSS's Avatar
Use it, it won't hurt.
I have also heard that RP should be changed at 3000 miles.
Old Dec 17, 2008 | 09:25 PM
boostedss26's Avatar
use mobil 1
Old Dec 17, 2008 | 09:27 PM
Schaeffer's Avatar
use mobil 1... other oils FTL
Old Dec 17, 2008 | 09:28 PM
Spanky's Monkey's Avatar
using amsoil right now and it's some pretty good ****.
all name brand oils are very good. wever used most name brands in our race motor and have all seen similar results. theyre all great products.
Old Dec 17, 2008 | 09:30 PM
Int0x's Avatar
thanks for the help guys.
Old Dec 17, 2008 | 09:31 PM
no problem.
Old Dec 17, 2008 | 09:32 PM
E-Town SS's Avatar
When it comes to different types of synthetics, they all have to meet specific requirements. They should all be fine. For them to say "this one doesn't mix well with oil A or B" is a bunch of crap and most likely said to sell more oil.
A good name brand synthetic is good. I've had douches tell me castrol is better than mobil 1, however, mobil 1 comes in the SS/TC and also GM vehicles like my dads TBSS.
Old Dec 17, 2008 | 09:35 PM
cobalt blue's Avatar
I just started using royal purple, and its pretty good ****. I wouldnt worry about mixing the oils, youre really not mixing all that much anyway. I find the best way to get all the oil out of your crankcase is to get the oil to operating temp.
Old Dec 17, 2008 | 09:37 PM
bryce712's Avatar
mobil 1 or bust !! but if its sae rated for newer cars and is a full synthetic youll be fine
Old Dec 17, 2008 | 09:38 PM
TurboTommy's Avatar
Royal Purple
Old Dec 17, 2008 | 09:40 PM
Ok lets hear some toughts on amsoil. They say it's good for 25000 miles. That the hell is that. All oil gets dirty and so does the filter. I would never go that long without not changing it.
Old Dec 17, 2008 | 09:42 PM
JimzSS's Avatar
thats what they say....they perfected the ****.
Old Dec 17, 2008 | 09:52 PM
E-Town SS's Avatar
If you're using synthetic oil, go by your oil life monitor. If you don't, you're more or less wasting your money. I remember when I was using the 3000 mile rule, the oil that would come out still looked pretty new. The reason for that is the oil life system was saying 62% or more.
Now I let the monitor go down to like 30% before I change it. If you're not running synthetic, I would stay with the 3000 mile rule.
That being said, it's your money so do what you want with it.
Old Dec 17, 2008 | 09:53 PM
JimzSS's Avatar
well put
I will say that Valvoline synthetic made my motor sound like marbles in a can at start up...lol
Old Dec 17, 2008 | 11:14 PM
Cobaltxfe09's Avatar
read sig
Old Dec 17, 2008 | 11:17 PM
red06SC's Avatar
M1 is junk compared to RP
Old Dec 18, 2008 | 10:56 AM
i'm waiting to see how it goes. just put it in last week and i haven't put any miles on it. i feel off the cuff it's better then the RP i used last oil change. and amsoil has a filter for extended miles but not in the cobalt app. i'm just gonna swap filters if this **** actually makes it too 3k.
Old Dec 19, 2008 | 10:01 PM
tomst9's Avatar
If RP meets the gm4718 spec, you can use it. It should say it somewhere on the bottle. If not, do not use it.
thanks,
tom
Old Dec 19, 2008 | 10:46 PM
Omnigear's Avatar
walmart oil 4tw
same **** bottled differently
Old Dec 19, 2008 | 10:52 PM
Schaeffer's Avatar
Originally Posted by Omnigear
walmart oil 4tw
you are absolutely correct.
Old Dec 23, 2008 | 11:51 AM
ghewly's Avatar
if your not running full synthetic, then you just voided your warrenty.
Old Dec 23, 2008 | 02:48 PM
rnjmur's Avatar
RP actually has less wear protection than mobil 1, which is how they are able to get performance gains when using their oil.
You shouldn't mix oil brands unless youa re sure they use the same basestock. Different basestocks do not always mix well and should only be done in an emergency. You can change your oil brands when doing an oil change and should be ok. Engine motors hold enough oil that you will flush out the old oil and mix with it enough that you won't see a problem. If you want to be 100% safe, just short change the oil (like at 1500 or 2000 miles) after changing brands, but again it probably isn't going to be necessary.
The oil actually drains best and fastest when it is COLD. The 5W30 rating means that the oil has a viscosity rating of a SAE 5 oil at COLD tempuratures and a SAE 30 rating at operating tempurature. With that said, the oil is thinner and flows better at COLD tempuratures.
I last changed my Mobil 1 extended performance oil at after about 7000 miles and I always change it about this amount (which is when the oil life monitor gets to about 10% ~ 15%. The lab results showed TBN was still at 6.5, engine has 55K miles but the oil shows no engine wear at all. I could easily go another 3000 to 4000 miles before changing the oil.
If you really want to know how your oil is performing, you need to send oil samples off to be analyzed. I send samples every oil change. It costs like $20 for analysis and an extra $10 for TBN analysis.
