oil feed line hookup
Old Oct 14, 2008 | 08:31 AM
bwalker0510's Avatar
so anyone wanna say what they think is the best place to hook up an oil feed line for a turbo on the lsj? if you got pics post them...please....
Old Oct 14, 2008 | 08:33 AM
Rangerondubz's Avatar
Here you go:
The blue circle is the oil feed line and the red is a spot where you can choose to drill and tap for the oil return
Just remember to search alittle next time
Old Oct 14, 2008 | 08:34 AM
i did i guess i missed it. and i dont wanna drill into the block for the feed line. especially in a spot like that. looks like trouble to get to since everything is installed. im just gonna drill the pan for the drain.
anyone else on the feed line.
Old Oct 14, 2008 | 08:40 AM
You dont have to drill an tap.....Just simply unscrew
This is the only place to get oil feed unless you go from the head which is not a good idea
Here is a closer up picture:
Last edited by Rangerondubz; Oct 14, 2008 at 08:45 AM. Reason: Automerged Doublepost
Old Oct 14, 2008 | 08:41 AM
oh ok well once the exhaust place is done with my dp ill take a look at it. what size fitting will i need. i take it youve done this? is there something there or is it just a plug. the pic didnt work.
oh it worked, now i see.
Old Oct 14, 2008 | 08:49 AM
Alright I hosted the picture on css.net
No I havent done this, im just about too
Here is the fittings you will need for the feed line, all of these can be had from vulcan turbo:
M12x1.75 metric to 1/8npt adapter then a 24" line should be good enough, also the vulcan lines fit directly into that fitting
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
