oil filter cap
oil filter cap
when you do your oil change does anyone else not put the gasket on the oil filter cap?
i havent the last 3 times ive done it and havent had a problem
one time i put it on and tightened it down too tight and it caused it to leak oil..good thing i checked it before i drove it
just wondering if you guys put the gasket on or not
thats a good question. I install the filter element in the housing first then tighten the cap. I use a torque wrench for everything. I have never replaced the O ring on the cap, but thats a good idea though. Props to you.
i've never done it on the hundreds of ecotecs i've worked on over the years but i inspect the one that is on the filler cap before i put it back on to ensure there is no damage. if there is i would replace it.
I always oil and replace mine.
I usually skip out on the AC filter, and buy a high quality aftermarket filter that includes the seal.
You won't have a problem as long as you oil it and it's seated properly.
yea i guess what i was saying is that i dont use one at all and have never had a problem mainly because that happened the first time.
whats it meant to be torqued down to? i usually just put it on there pretty tight
like i said i replaced it once and tightened it down pretty tight causing it to gap and leak oil out of the filter and cap so i just took it off and havent put one back on for like 3 or 4 oil changes
so since you guys say i should how hard should i tighten the cap im assuming not very hard but its difficult to tell when its so far down in there
get it sitting flush with the housing and then snug it up. doesn't need to be extremely tight. and the seal should be in the groove that is on the filler cap and from what you describe it wasn't in that groove causing it not to seal properly
