Oil on K&N Air Filter
Old Dec 1, 2005 | 02:58 PM
JCswoosher2's Avatar
I got a check engine light. i was guessing it was from the oil on the filter getting on the MAF. so i poured cat litter on my first and it soaked the oils right up. it worked great.
Old Dec 1, 2005 | 03:53 PM
astrocrep's Avatar
Uhhh Wierd... but interesting...
If it works... it works...
-Rich
Old Dec 1, 2005 | 03:55 PM
Chevypowered's Avatar
What i did was spray on the oil then blew the filter from the inside out with some air to get the extra oil off, i got the fujita but same deal. 500 miles no codes.
Old Dec 1, 2005 | 04:15 PM
JAESS's Avatar
I don't think its the oil. When I put my k&n in the light came on two days later. I drove the car for a week and then I put my stock unit back in and the light went off and stayed off. I drove the car for a week with the stock unit back in and no light so I put the k&n back in and the light came on the same day. If it was the oil the light would've stayed on for awhile after installing the stock intake. Thats my 2cents.
Joe
Old Dec 1, 2005 | 04:42 PM
lol i posted that just to see what people would say. dont go pouring cat litter on it. yeah i guess its just the k&n. is there anyone who has solved the CEL problem>?
Old Dec 4, 2005 | 09:37 PM
Lil Blue SC's Avatar
I put mine in on a cold day drove not even 50 miles and it came on 30 degree weather... today it was upper 50s never came on again till tonight when it got back down to the 30s....
Old Dec 5, 2005 | 12:12 AM
fiShYs-'s Avatar
seems like my CEL only goes on when its 6 degree Celsius and lower
can any1 with the CEL on or off post the temperture of ur area down
Old Dec 5, 2005 | 12:35 PM
desperado's Avatar
Lean
If I had to guess what the problem was it would be a lean code. From what I've ready about the cobalts fuel injectors they are alsomost maxed so when adding a CAI And on top of that when the ambiant temp is low their is a greater volume of air intering the engine. The MAS and MAP sensiors read the increase of air to fuel as out side it's programed perameters. The sock injectors will probably need upgrading along with a reflash to browden the parameters and add more fuel. The reflash will probably allow more radical future mods with out the troublesome CEL showing up. I would like to see what the max capabillities of GM's Stage 2 kits will be. This is all just my opinion guys gathered from previous experience. I hope you can find out more factual data To better help you with your moding. It would be a good Idea to get info from GM sence it was programed an engineered buy them. Good Luck with the CEL's.
Old Dec 5, 2005 | 01:13 PM
selfinfliction's Avatar
been running the welfare airbox mod with spectre filter for around 7000 miles and no cel's yet
so i guess that could be considered a solution
no_ss
Oct 18, 2015 11:58 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
