Oil level
Old Nov 3, 2007 | 12:11 AM
L.P.'s Avatar
Oil level
Is it okay if I put 6.5 qts of mobil 1 in or is that bad?
Old Nov 3, 2007 | 12:13 AM
D4u2s0t's Avatar
ummm..... that's how much it takes
Old Nov 3, 2007 | 12:14 AM
L.P.'s Avatar
Just making sure..everybody says it takes 6qts...will a little bit over full hurt anything?
Old Nov 3, 2007 | 12:15 AM
D4u2s0t's Avatar
6.5 is perfect, that's where it's full on mine. 6 quarts is a tad low. just check the dipstick to see how high it is. if you're scared you put too much, and it's over the fill line, you can always just drain a little out.
Old Nov 3, 2007 | 01:00 AM
L.P.'s Avatar
THank you I put 6.5 qts in so I should be fine.
Got another question I just went out to check the oil and make sure its just a little bit above the full mark but it has been sitting for 8 hours does that mean I need to drain a bit out?
Old Nov 3, 2007 | 01:02 AM
RBC's Avatar
RBC
Well were did it show on the stick?
Old Nov 3, 2007 | 01:04 AM
L.P.'s Avatar
Just a bit above the full mark. But that was after 8 hours of sitting.
Old Nov 3, 2007 | 01:05 AM
D4u2s0t's Avatar
what is just a little? a millimeter or 2? that would be fine. since it's getting cold out, and oil is thicker when it's cold, warm the car up, then check it. if it's still over the line then you can drain some out. if it's barely over it's not anything to really worry about.
donjuaniii's Avatar
Make sure to check out the owner's manual ... I believe it states to check the oil 5-10 minutes after shutdown ... and not after it's totally cooled off
Old Nov 3, 2007 | 01:07 AM
L.P.'s Avatar
I done that earlier today and it showed right below full just a bit below it.
D4u2s0t's Avatar
read my last post
Old Nov 3, 2007 | 01:08 AM
RBC's Avatar
RBC
YOu will be fine. When It is cold for a long period of time and on a flat area that will be the most oil that will end up in your pan.
Old Nov 3, 2007 | 01:10 AM
L.P.'s Avatar
I'm just paranoid because I am going to Bowling Green KY in 2 weeks which is almost 7 hours away from me to drag race at a sea level track.
Old Nov 3, 2007 | 01:11 AM
D4u2s0t's Avatar
nothing to worry about. but damn, that's a long drive!!
donjuaniii's Avatar
read my last post
Looks like we posted at the same time
Old Nov 3, 2007 | 01:23 AM
L.P.'s Avatar
It really is but a group of my friends from a local forums are going we are just tired of fighting with the altitude and the sucky traction they give us at our local track so we are going to a sea level track the 17th of this month. Its going to be a long ass trip but that is the fathest I've ever been towards west and plus we are going to drop down and go to nashville and club a bit should be a great trip.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
dennis69
Sep 28, 2015 02:16 PM
