Oil Pan
Old May 20, 2011 | 12:48 AM
insylem's Avatar
Oil Pan
Hello,
I'm considering modifying my oil pan to use an oil temp sensor from Aeroforce.
My question:
How simple and straight forward is the removal and installation of the oil pan?
I realize there is no gasket, so what is used to seal it?
What all am I going to have to disconnect to get the oil pan off? Once the bolts are out will it be a pain in the ass to get the oil pan off the block?
Thanks,
Old May 20, 2011 | 12:54 AM
Mnatvyc1223's Avatar
Originally Posted by insylem
Hello,
My question:
Thanks,
use this to seal it up after removal of the OLD sealant.
http://www.permatex.com/products/aut...sket_maker.htm
oil pan removal is pretty straight forward, once all the bolts are removed (i can't remember if there are any other interferances) use a pry bar and gently start pulling the pan away from the block. patience is a virtue, believe me.
Old May 20, 2011 | 03:11 AM
insylem's Avatar
So where is the best place to get an oil pan from? I dont feel comfortable modifying mine myself if its the only one I have. Id like to have an extra for 'in case' i screw up.
Old May 20, 2011 | 03:12 AM
insylem's Avatar
Good info, thank you sir (or mam?)
Old May 20, 2011 | 12:01 PM
best place for an oil pan would be from a pick a part junk yard or from GM itself. i'm a dood btw
Old May 20, 2011 | 01:28 PM
mrbelvedere's Avatar
gm part number for bottm end engine sealant 12378521 you can get it from local gm dealer or here http://www.partscentralusa.com/Produ...6/Sealant.aspx
or use threebond1280b-gm
biniecki
Oct 25, 2015 02:23 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
