Oil problem Someone please HELP!
Old May 16, 2010 | 12:33 PM
sick_ss/sc's Avatar
I just changed my oil, and i already put in 6.5 q of oil..and my dipstick is still reading no oil..im scared to add to much..what should i do??
Old May 16, 2010 | 12:36 PM
Mclovin23's Avatar
calm down.. to much oil is better than not enough. did you completely drain it first? did you let it sit for awhile before you checked? i usually put in six quarts when i change my oil so 6.5 i would assume would be fine. if your worried its too much. drain a little from the oil pan and slowly put in more
Old May 16, 2010 | 12:38 PM
sick_ss/sc's Avatar
ive changed the oil atleast 10 times since ive had the car..no leaks no burning..nothing..should i add more
Old May 16, 2010 | 01:03 PM
Mclovin23's Avatar
if you added 6.5 quarts already i would say no. the oil had to have gone to the oil pan, unless thats somehow leaking (which you would know) it has to be in there.
Old May 16, 2010 | 02:26 PM
selfinfliction's Avatar
i would just fill it the rest of the way up with water, it's cheaper
Old May 16, 2010 | 02:35 PM
Frew's Avatar
lolz
Old May 16, 2010 | 06:53 PM
terry11's Avatar
was the car running when you checked it? haha
Old May 16, 2010 | 07:00 PM
i wouldn't even take this thread seriously, the only thing that happened is he left the drain plug or filter loose and it ran out.
#1 he said he "just changed the oil"
#2 if it was burning that much oil, it would look like a locomotive and he would notice it
#3 if that much oil is leaking into the water jackets, the car is so fubar there's no way it's running properly
so that leaves: a loose drain plug or oil filter that is leaking
Old May 16, 2010 | 07:03 PM
terry11's Avatar
Well it almost made my day :P
Old May 16, 2010 | 07:15 PM
tanelk's Avatar
i only use 5 quarts and it fills up to the dipstick, and your using 6.5, let it idle for a while then check.
Old May 16, 2010 | 07:49 PM
Frew's Avatar
if the engine is hot more oil will drain from the valvetrain and rotational assembly then when its cool fyi
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
