Okay so, this is probably a repost, but...
I've been driving my car and the battery has been dying, It seemed like a weak battery so I took it to carquest and had them charge it, after a while it had died again. Today I was driving home from school and the battery died while driving the car still ran but I lost all power steering and stuff.. Keep in mind it's like 30 degrees outside and my car has been sitting there without being driven since June. It might be the alternator but I'm dying to here that it's my battery for lack of money. I'm broke the car has been such a nightmare. Never had a problem with the alternator before my car hydrolocked so I'm really not sure what's wrong.
It sounds like you battery, but I wouldn't think it would just die when you were driving. That just doesn't sound right. I guess if you are short on money you could try and get a new battery, but from what I have experienced it is an altenator problem. Im not 100% tho
had the same problem after my car sat a few months doing the turbo swap lol alternator **** the bed...if its not keeping the battery charged it's most likely the alternator....take it off and go to autozone and have them test it it's like 5 bolts including the leads to take off maybe 10 minutes
If it's dying while you're driving it, you need to check the alternator as well as the battery, like others have said. Willing to bet you'll find that that's the problem. I had that happen on my old Cavalier. Also, pay the extra however much it costs to REPLACE the battery (even if it's new and even if they tell you it's fine), could have saved myself another 6 months of headaches if I'd just replaced the battery when I replaced the alternator.
Trust me, it's better than the alternative. When the alternator **** the bed in my Cavalier it was a major major major headache to get everything fixed. I had been out of town and a friend had driven it for like 2 weeks with a bad alternator, and they just kept using the battery tender thing I had to recharge the battery instead of, you know, getting it fixed.
here is a simple way to test it, all you need is a volt meter. hook the volt meter up to the battery. is it bellow 12.45 volts with the car shut off? if so, your battery is getting weak. start the car, when cranking does the voltage drop bellow 10.5 volts? if it does, your battery is junk. with the car running at idle, is voltage above 13.8? if not, your alternator is weak. turn everything in the car on with it running, headlights, high beams, fan, stereo, 4 ways, etc. with all that on, is the voltage lower than 13.5? if so, your alternator is bad.
id put my money on a bad alternator. however, your battery may now be bad as well. the battery is not meant to be discharged and charged back up, its meant to provide a short burst of high current draw, then be charged back up slowly by the alternator. every time the battery goes dead and you have to jump/charge it, it loses life.
I just ordered a new alternator and have a perfectly good and working one. Ordered a new one for the turbo swap. Make me an offer if your intersted on the old one. Nothing wrong with at all.
