Opt b install question
Old Mar 24, 2011 | 06:45 PM
nizzle's Avatar
In the opt b kit the is a brass fitting that screws into the top of the stock HE. There is a little plastic piece that inserts into the brass fitting and then into the bleeder hose. The plastic piece fits snug into the bleeder hose but fits a little loose inside the brass fitting.
Is it supposed to be like that or should the little plastic piece fit snug inside the brass fitting?
What is the little plastic piece for?
What will happen if I just connect the bleeder hose directly to the brass fitting with no little plastic piece?
Old Mar 24, 2011 | 08:23 PM
nizzle's Avatar
Somebody? Anybody?
Old Mar 24, 2011 | 08:27 PM
Sylver01's Avatar
Who did you get the option B kit from?
Old Mar 24, 2011 | 08:29 PM
nizzle's Avatar
either zzp or crate engine. I cant remember.
05Slowline's Avatar
lmao. sorry. it doesn't go in the brass piece though you stick it smallest end toward the opt b tank big end towards the brass in the top of the h/e.
if you don't have it in it won't bleed air correctly.
Old Mar 24, 2011 | 08:35 PM
Sylver01's Avatar
I ordered the .040 oriface from Crate engine depot. it goes inline between the bleeder fitting and the option b tank.
I got the ottp kit but didn't want to mess around witht the little piece of plastic they sent.
Old Mar 24, 2011 | 10:27 PM
nizzle's Avatar
So it does not attach to anything? It just sits in the hose?
Old Mar 24, 2011 | 10:43 PM
Sylver01's Avatar
That's what it looked like to me. if you put it in the brass fitting it would have the potential to actually fall inside the heat exchanger and get caught up in pump.
Old Mar 24, 2011 | 10:53 PM
05Slowline's Avatar
correct, it's necessary for the proper operation of what option b is almost all about
Old Mar 24, 2011 | 10:55 PM
nizzle's Avatar
thx for the info. 1 more question. The little plastic piece in the tube sits close to the brass fitting right? Or closer to the tank?
Old Mar 24, 2011 | 11:16 PM
shadowfaxss's Avatar
next to the brass fitting is fine.....
Old Mar 24, 2011 | 11:20 PM
nizzle's Avatar
Awsome. Big help. Thx.
Old Mar 25, 2011 | 09:08 PM
05Slowline's Avatar
yea doesn't matter long as it's in the line
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
Bohb
Sep 27, 2015 09:11 PM
