Option B with flowthrough tank vs expansion tank
Old Jun 3, 2010 | 09:51 AM
Sergio's Avatar
As the title suggests if you were to setup Option B as GM reccomends (expansion tank), it would bleed air well but not really increase your coolant capacity. If you kept the bleed line but placed the tank in series of the coolant loop, would it bleed just as well?
If anyone runs such a setup and can post some IAT1 and IAT2 after a long pull that would be great
Old Sep 8, 2011 | 11:04 PM
xxxxsh4d0wxxxx's Avatar
Great question and I'm looking for the exact same answers.
Old Sep 9, 2011 | 12:52 AM
euthanasia's Avatar
Anytime you can add more water to the system is a good thing.
Old Sep 9, 2011 | 05:02 AM
advise's Avatar
any chance that cap with bolt in place the other style back one
like the stainless bolts
Old Sep 9, 2011 | 07:12 AM
Staged07SS's Avatar
Administrator
Administrator
Here's a little clip from the GMR Stage 3 kit:
What’s the purpose of the second surge tank?
The second surge tank is for the aftercooler. Without it, it is very difficult to purge the air from the system. Using the additional surge tank ensures a fully purged system with no trapped air. This higher pressure system will provide an added level of efficiency for the intercooler system.
The Opt. B setup does add more coolant to the system, but it will not be used like it would be in a flow throw setup.
I've been running the Opt. B setup for 3 years now, and it has worked great. I have never used a flow through tank myself, but some members have found that it helps.
Old Sep 9, 2011 | 07:45 AM
Right. It has an exit line and a bleeder line. As air is removed it will take coolant as it needs it from the reservoir. There is no return line, I roger that.
I would like to know really how much of a difference we are talking here with an actual flow through verses the standard GM Opt. B.. For some reason I can't see it making much of a difference.. I'm not sure why.
Old Sep 9, 2011 | 12:43 PM
sLAsh's Avatar
Look at hatrick stu mod for flow through vs option B
https://www.cobaltss.net/forums/2-0l...ox-mod-166658/
Old Sep 9, 2011 | 12:48 PM
nizzle's Avatar
sub'd
Old Sep 9, 2011 | 03:25 PM
Bluelightning's Avatar
Got Bewst?
This is exactly what I've wanted. Do you make them enthanasia? Does it go where the option b would?
Old Sep 9, 2011 | 05:32 PM
euthanasia's Avatar
This is what im running
Old Sep 9, 2011 | 05:33 PM
nizzle's Avatar
Thats your opt b flow thru?
Old Sep 9, 2011 | 05:41 PM
euthanasia's Avatar
Its a flow thru system and yes its mine lol. opt b and my flow thurs are not the same thing. 4 gal of water makes it nice lol.
Old Sep 9, 2011 | 06:26 PM
What's the difference. A radiator does not have a constant flowing system.. And it is perfectly efficient seeing as how the motor doesn't overheat and it cools parts that are running a high duty cycle at all times. You are not in heavy boost 100% of the time. I believe with option b, a FMHE, and dual pass you are about efficient as you're going to notice.
Old Sep 9, 2011 | 06:40 PM
euthanasia's Avatar
Its simple opt b tank does nothing for cooling. Thats the diff between it and a flow thru tank that holds more water.
Old Sep 9, 2011 | 06:46 PM
nizzle's Avatar
pardon me for asking stupid questions but that is in your trunk right? The stock IC pump doesnt have any problems pumping fluid that far?
Old Sep 9, 2011 | 06:54 PM
zrated89's Avatar
dam jr size matters huh? lolz
Old Sep 9, 2011 | 07:07 PM
evofire's Avatar
i am subbing to this!
Old Sep 9, 2011 | 07:15 PM
RooTBeeR's Avatar
i have see juniors fish tank in action lol looks like it was pumping/flowing just as well as the stock "T" Bottle setup
Old Sep 9, 2011 | 07:44 PM
zfissette's Avatar
the flow through tank increases the system capacity and thus its thermal storage capacity. it takes many more btus to raise the temperature of 5 gallons of fluid than of 1 gallon so by having a big storage tank you can ensure that the intercooler itself has cool fluid running through it for the entire pull. the next level is of course active intercooling, where you push the temp of the fluid below ambient using the ac system as a chiller. for most applications option b and dual pass are enough, for more aggressive setups a fmhe or griffin are fine but for top end stuff you need to break out next level ideas like the flow through tank and active intercooling
Old Sep 9, 2011 | 08:24 PM
wRcKLes's Avatar
saved for later
Old Sep 9, 2011 | 08:40 PM
Powell Race Parts's Avatar
that statement is so wrong. For a guy like you who does good work and is smart its a surprising statement. Here is why your statement is wrong. The stock OEM h/e cooling system does not self bleed air.
Option B takes care of air entrainment in the coolant. With air in the coolant, the laminova cores cannot transfer heat from the inlet air charge to the cooling system efficiently, as the cores require contact with water, not air bubbles.
take out the air bubbles as option b does very well, then the system cools efficiently, which makes option B do A LOT for cooling; lower IAT2 numbers are the proof.
Old Sep 9, 2011 | 08:47 PM
u r right! other than fmic suck lol
Old Sep 9, 2011 | 09:16 PM
euthanasia's Avatar
Which is why the black tank in the pic has a tube to hook up a hose to the h/e to bleed the air you speak of. I have had that tank in my car for many months at one point and never had to to add any water.
Old Sep 9, 2011 | 09:35 PM
nizzle's Avatar
Why is that? Also, I've been trying to contact you guys all day to order some rotated mounts. Talked to Gloria earlier and sent a text with all my info. Wut up?
Old Sep 9, 2011 | 09:41 PM
if you talked to Gloria you are set. i was on the road picking up parts in NY state and doing shipping stuff.
front mounted h/e are cheeap. Chiwanese, not always cores designed for heat exchanging. not always dual pass. look at the thread zoomer did on his core versus the others with cutaways.
partially block radiator assembly.
do not benefit from the air damn positioning
or the cooling fans.
is that enough?
race griffin. is best.
if you read the zzp thread zoomer said something like " the stock oem h.e is very good just not enough of it" or words to that effect.
so race griffin .
