the other top motor mount
Old Sep 15, 2012 | 12:46 AM
Shogokuma's Avatar
whats the part number and how do i change it?
sorry 2006 lsj
Old Sep 15, 2012 | 01:12 AM
bluebalt07's Avatar
The piece that bolts to the frame is 25829028. The piece that bolts to the top of the trans is 25827450. To change it you will need to pull out the fuse box and the mount will then be in plain sight and it's a simple matter of undoing the bolts. Just make sure you have the engine supported.
Old Sep 15, 2012 | 01:17 AM
Shogokuma's Avatar
thank you so much is the lsj mount the same as the LNF if its different is it better and does it fit the lsj?
Old Sep 15, 2012 | 06:05 PM
bluebalt07's Avatar
No problem. They show as the same part number for either the LSJ or LNF
Old Sep 15, 2012 | 06:20 PM
Shogokuma's Avatar
i think that mount might be going bad do they usually go bad i have a bad wobble in second gear
Old Sep 15, 2012 | 06:35 PM
bluebalt07's Avatar
I don't know if they are prone to going bad. Never really heard anyone else say they have problems with it. I know that I had mine off at like 85k miles or so when I was replacing my clutch and it was fine
Old Sep 15, 2012 | 06:48 PM
jp1600's Avatar
You know what wobble in second is?????? Axle bind, still have it with a zzp motor mount, and ottp rotated mounts... Get rotated mounts and it will help, or raise ur car up some
Old Sep 16, 2012 | 06:16 PM
Shogokuma's Avatar
it was bad in first gear, then i installed powell rotated with an LNF rear, my car has the lnf suspension with canuck springs, its only 1 in in the front
after the mounts its only in second gear now the first is no wobble at all
i have 156k km on it, just had the cylynder head replaced i had a bad head gasket too i bought this car used in 08 and it only had 67km on it and was loosing coolan so it wouldnt suprise me if that mount was bad the tranny mounts where shot and i mean shot the rubebr was all curled up in the mount
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
