OTT Rotated Trans Mounts
OTT Stage 2 mounts are winsos.
If I ever went back to stock I'd keep them on. They do wonders for your car. And don't pay any mind to the '300 whp' thing. Stock or not, they're worth every penny of the buy.
I do 2nd gear burnouts at the track on drag radials and the front end stays seated. Clutch dumps on the street and nothing.
As Blazin07SS said. Just spin spin spin.
thanks for the sarcasm stu.
So they are rubber correct they are not polyurethane?
ok well I just want to make sure there not polyurethane. I looked at the mounts and they don't even look like a polyurethane insert like what you see conpanys sell they look like a smaller regular rubber mount that's on the factory tranny mounts.
I probably should have updated the post way back when I got them. The mounts are awesome and I'd never go back to the stock mounts even if the car went back to stock. Launches are ridiculous and roast like crazy.
Fact is: solid=mucho horrible vibes
torque damper = some vibes (by itself)
stage1 OTT = vibes hard to detect
Stage 2 = Idle vibes are noticeable , see above
Poly inserts= lotsa vibes some people like it
me personally, who invented them damn rotated mount stuff, I have 300+whp and track my car and have stage 1 only. I am not sure what to do about the drag strip, some of the issues come from the drivers side upper mount which is really soft. I am working on a solution, filling the darn thing with Poly wont do it...
on the meantime, some days I get "tramp" not hop (coz it aitn violent) on some weird surfaces havent figured it out happens like three or four times a year. I am smart enuff not to keep in it.
Drag strip? this needs work. Launches need driver mod more than car mod imho.
Last edited by qwikredline; Dec 11, 2009 at 01:30 PM. Reason: Automerged Doublepost
seeing as how you dont have a cobalt anymore and havent tried all the above how would you know?
Wow, you clearly are a ******* retard arent you. Why dont you go search my build thread. Better yet here is the link... https://www.cobaltss.net/forums/canadian-mid-west-112/snakes-tvs-build-179214/
I had a TD on my cobalt for 1 1/2 years, then bought the engine mount and stage 2 rotated mounts. Only thing i didnt have was the poly mounts. People told me you couldnt have a TD and Stage 2 rotated mounts.....i proved them wrong, people then told me you couldnt have solid engine mount with the rotated mounts, i proved them wrong again. I tested these combos....
TD by itself - no wheel hop on the streets but on the track got quite abit. Little vibs
Solid Engine mount - had wheel hop on and off the track, same abit more vibs the the TD
S2 rotated mounts - no wheel hop on the streets but a little on the track, little vibs
TD with S2 mounts, no wheel hop on or off the track, lots of vibs.
So next time you make a post claiming someone didnt have something, i suggest you do abit of research
