OTT Stage 1 dyno numbers
Old 02-25-2009, 10:59 PM
Red07Coupe's Avatar
Post OTT Stage 1 dyno numbers
Has anyone here taken the OTT stage 1 kit on the dyno yet? I just want to compare the OTT kit to my GM stage 2 kit and see what kind of difference there is as far as hp and power curve.
Any info would help guys, thanks
Old 02-25-2009, 11:10 PM
wtpcobaltss's Avatar
nope i havent had mine dynoed yet but my interceptor gauge is reading about 325 crank. thats with ott stage 1, v2 header, catless stock downpipe,injen intake,oil breather,front mount h/e, with extra coolant resi. and 12.2 afr on 17 psi
Old 02-25-2009, 11:19 PM
06 pursuit gt's Avatar
Sean said in the group buy thread for the stage 1, 250~255 whp https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/ott-stage-1-gb-148005/
right now id say your at maybe 230~235 whp. so their kit plus your exhaust you should be in the 260's.
Old 02-26-2009, 01:29 AM
Red07Coupe's Avatar
Post
Originally Posted by 06 pursuit gt
Sean said in the group buy thread for the stage 1, 250~255 whp https://www.cobaltss.net/forums/showthread.php?t=148005
Okay thanks man, I guess the kit is worth getting then. I just didn't want to drop $425 for a small gain.
Thanks again
I'm also looking at getting the ZZP downpipe an OTT HE in the near future, can't wait.....
Old 02-26-2009, 01:37 AM
Dustinss's Avatar
I dynoed my gm stage 2 and made 250whp with a 2.9 full exhaust on a dynojet
Old 02-26-2009, 01:52 AM
Red07Coupe's Avatar
Post
Okay, looks like I have to look into this deeper now.... I might just wait it out till next year and just get a bunch of supporting mods instead.
Is that you on youtube with the black ss/sc that ran 250?
Old 02-26-2009, 12:35 PM
domin8_gt's Avatar
Think about it this way. You need to get bigger injectors when you get small enough pulleys. Failure to do so will lead to static injectors. Changing the pulley and/or injectors requires retuning. The proper exhaust will help any setup you have. OTTP is really the next step up from GM stage 2. However, since you already have the stage 2 belt, I'd probably trying looking around and pricing out individual parts to try and save a little money. Everything in the OTTP stage kit can be purchased seperately from OTTP too. I did a comparison and I think the OTTP stage kit only saves you a few dollars versus paying the parts individually.
Old 02-26-2009, 12:38 PM
ebristol's Avatar
Here is my dyno of the OTTP Stage 1 Kit
Old 02-26-2009, 12:43 PM
SCcobaltSS's Avatar
Holy **** 8% humidity! that is amazing... Your air density is really good. nice numbers
Old 02-26-2009, 12:46 PM
mexi_loco's Avatar
Just thought I'd give you the specs on each stage kit:
OTTP Stage I:
-60's Flowmatch Injectors
-Nate's 2.8" Smoothflow Pulley
-NGK 1 step colder Plugs
-PCM Tune (depends on what mods you have)
-Price = $425 or so
GMPP Stage II:
-42lb. Injectors
-3" pulley
-Smaller Belt
-Reflash (adds more fuel to the powerband, and raises the rev limiter)
-Price = $550
Right now, I'm running the OTTP stage kit, but with a 2.7" pulley. I basically went from stage none, to GMPP Stage II, to OTTP stage 1. Honestly, although I haven't gone WOT yet on the OTTP stage kit, I say it's the best bang for your buck.
As far as dyno numbers, I've heard they're different depending on what dyno you use. But consistently, OTT has more gains than the GMPP kit. But that's a given when you consider they have a smaller pulley and bigger injectors than GMPP.
Old 02-26-2009, 01:15 PM
Red07Coupe's Avatar
Post
OTTP Stage I:
-Price = $425 or so
GMPP Stage II:
-42lb. Injectors
-3" pulley
-Smaller Belt
-Price = $550
Thanks for the info man, its good to hear from someone who actually went from a Stage 2 to the OTT kit. That's what I wanted to do, run the OTT kit with the 2.7 pulley, did you ask for that when you first ordered the kit?
ebristol
Is that a dyno run with just the OTT on a stock motor with no exhaust? what were you running whe you had that run?
Old 02-26-2009, 01:44 PM
mexi_loco's Avatar
ebristol
nah. I was originally going for the 2.8". But what happened is that my friend and I swapped s/c's (long story short...we didn't want to pay money to pull off the hubs). The hub on his s/c wouldn't fit on the 2.8, so I just said **** it and kept the 2.7".
Old 02-26-2009, 03:45 PM
ebristol's Avatar
Mods:
K&N CAI
GMPP Manifold
ZZP DP
Magnaflow Cat-back
LS4 TB
OTTP Stage 1
CX Racing Dual Pass HE
I probably could have picked up 7-8 whp by replacing that GMPP exhaust manifold with a header.
Those are pretty good numbers for a safe/reliable tune. Or I could have drove 40 minuets to a Happy dyno and put down higher numbers.
Don't put too much emphasis on dyno numbers. Unless you have a baseline on the same dyno to compare them to.
Old 02-26-2009, 04:17 PM
Red07Coupe's Avatar
Post
Mods:
K&N CAI
GMPP Manifold
ZZP DP
Magnaflow Cat-back
LS4 TB
OTTP Stage 1
Thanks man, and I hear what your saying about dyno numbers, I just wanted something to show me where this kit stands. Everyone raves about this kit and I just want to see for myself if its all that its made up to be.
I'm running almost the same mods you are minus the DP, TB and HE, but they are mods I plan on doing if I decide to keep my stage 2.
Old 02-26-2009, 04:23 PM
mexi_loco's Avatar
you don't necessarily need to do the h/e if you're not planning to run any smaller than a 3" pulley on it. At least that's what I was told by one of the OTT guys. Definitely do it if you decide to run the ott stage kit, dual pass if you can help it.
01-12-2016 12:01 AM
maliki778
10-01-2015 07:39 PM
SSLOW06
10-01-2015 07:21 PM
09-27-2015 08:53 PM
metroplex
09-27-2015 07:48 AM
Quick Reply: OTT Stage 1 dyno numbers
