OTT stage 1 installed!!!!
Old Nov 26, 2008 | 01:28 AM
Bumpin Balt's Avatar
Is it safe to say a car with this kit would probably make about 10hp more than an equally equipped car with GM Stage 2? The fact that it comes with 60# injectors is a huge plus.
Old Nov 26, 2008 | 11:46 AM
lsjwannabe's Avatar
Yeah thats a safe bet to say
Old Nov 26, 2008 | 11:47 AM
Greased's Avatar
id say more than ten on average more like 15? probably
Old Nov 26, 2008 | 11:50 AM
lsjwannabe's Avatar
On the same dyno using the same cf you should see that gain the bigger gain is the more broad tq band.
Old Nov 26, 2008 | 11:51 AM
CobaltVenomSS's Avatar
i raced bitz when he got the kit installed and he only beat me by a car..and i got full exhaust with stage 2
Old Nov 26, 2008 | 11:54 AM
lsjwannabe's Avatar
That full exhuast helps out a nice bit as you can see He is just a catback right?
Old Nov 26, 2008 | 01:47 PM
yea...but his redline is still 6500...so he is gonna get his car logged and get kyle (our tuner) to work on the tune...its badass tho
Old Nov 26, 2008 | 01:50 PM
Nice! More torque FTW!
lsjwannabe's Avatar
Why's that? his redline?
Old Nov 26, 2008 | 03:15 PM
qwk05SS's Avatar
His redline should be 7k or 7200. I know Josh set my limiter to 7200
Old Nov 26, 2008 | 05:50 PM
  #36
i have no clue
Old Nov 26, 2008 | 06:49 PM
  #37
You can also select a 7400rpm redline. Is that safe on a stock engine though or would high speed valve springs be recommended?
Old Nov 26, 2008 | 06:53 PM
  #38
Deathcult's Avatar
im waiting till next check and im ordering this
cant wait.
question...why would i want to remove torque management? and whats the benefits of it?
Old Nov 26, 2008 | 07:46 PM
  #39
qwikredline's Avatar
No yes
Old Nov 26, 2008 | 07:51 PM
  #40
camarokiller's Avatar
Sounds like they didnt flash the tune??
Old Nov 26, 2008 | 07:59 PM
  #41
Originally Posted by qwikredline
No yes
Would a 7200rpm redline be safe? I would probably still shift at 7000, but it would be nice not to bounce off the limiter if I hit 7001rpms!
Old Nov 28, 2008 | 07:07 PM
  #42
bbitz06's Avatar
i had mine set to 7200 for the same reason so i could shift at 7 and not hit the limiter but its still at 6500 i still have to log and it should be changed when i send it back to ott just waiting for a nice day to do it
no they deff did we looked at it in hptuners when we flashed it on there are a lot of changes just not the redline but should be changed soon
Old Nov 28, 2008 | 07:15 PM
  #43
Figured i would ask. IDK if you did the flash yourself or you sent the PCM to josh and sean. I remember when the GM stage kist came out and the techs wernt flashing the tunes
Old Nov 28, 2008 | 07:22 PM
  #44
bbitz06's Avatar
no its kool yea we did it... ha dang glad that didn't happen to mine
Old Nov 29, 2008 | 05:42 PM
  #45
ebristol's Avatar
If you look at the power band you start loosing hp after 6500. So the only reason you would push it higher the that is to start at a higher RPM in the next gear
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
