OTTP A/C Condensor Brackets
Old Apr 16, 2012 | 08:37 PM
YelCal7's Avatar
Hey Guys, I wanted to know if I don't want either ZZP S3 or OTTP S1 Heat Exchanger. I want to use just OTTP A/C Condensor Brackets to move my A/C Condensor out but same stock Heat Exchanger to get more cool air coming through. Will that work to cool stock heat exchanger? I am on 2.9 pulley, option B tank, dual pass, phenolic spacer is in my car. I know the more cooling the more better. What you guys think ?
Old Apr 16, 2012 | 08:40 PM
Powell Race Parts's Avatar
not worth the effort to move it out as it wont make much of a difference. But try it. You dont need brackets, just bend the upper tabs on the ac condensor and put a spacer in the lower one...
Old Apr 16, 2012 | 08:47 PM
YelCal7's Avatar
Cause, I was thinking A/C condensor is in the way and it's blocking some air that is going through to heat exchanger. That's why I am saying to move A/C condensor out alittle and let more air go through to heat exchanger like let it breath. Instead of A/C condensor is too close to heat exchanger then that's the problem cause it's not getting much air to cool it down.
Old Apr 16, 2012 | 11:30 PM
ebristol's Avatar
I remember someone relocated the Stock HE in front of the AC condenser. But I never saw pics or any details on it.
Old Apr 17, 2012 | 12:21 AM
YelCal7's Avatar
Does it prove to cool IAT down ? Or better off getting ZZP S3 Heat Exchanger ? But if I move A/C condensor alittle and put ZZP S3 Heat Exchanger. I think it will cool WAY down more than you even know. Doesn't hurt to try that out. AW HECK! I'm gonna do this.
Delta coupe
Sep 30, 2015 08:11 AM
dennis69
Sep 17, 2015 12:52 PM
