OTTP can u explain this???
Had a non local lsj come by to have his his h/e installed by another member. Well middle of the night I get a call to come over bc they need a drill bit.
Thinking these guys r on crack I came over to help out. Well I show up to them installing your stg1 kit w/smoothflow 2.8" pulley and your new h/e...the h/e is the coulprate...the tabs you guys welded on the h/e don't, I repeat do t line up with the factory holes on the impact bar. Your brackets are to spaced out. We had to drill new holes. Which I don't mind. But this was sold as a bolt on kit. Wanting to k ow why you would delibrately place the brackets so far off...they weren't even close to being aligned right.
And another concern. When the h/e arrived it had a bent bracket, it was bent downward....
The fins on the h/e were bent in some places. And ontop of it all you didn't provide us with enough hose to bolt it all on. Well u did, but barely.
I would sugget:
-pakage ur boxes to survive atleast a 5ft fall w/out poduct damage
-include atleast 6ft of hose 3/4" hose
-make sure u were ur brackets in the right place
Pics of bent bracket will b up in a sec. And pics of how ur brackets are line will b posted later tonight when I get off work to take the pics
Ps: I won't give out the members names, but if hey want to chime in they know who they r
I would sugget:
every one ive ever seen you had to drill holes for. you cant blame shippers for shipping damages. have you see how places handle packages? everything i have gotten from them was in perfect shape.
