OTTP Long Tube Header
Old May 31, 2010 | 01:24 AM
  #1151
Area47's Avatar
Rent me! per hour
no, i am saying people should dyno their cars after putting the header on.
Old May 31, 2010 | 08:32 AM
  #1152
Deathscythe's Avatar
Going from the wet noodle header to the deepthroat longtube header.
Old May 31, 2010 | 09:15 AM
  #1153
BlackSSNick's Avatar
I want to order this but I want to hear some fly-bys with an aftermarket catback, let's go ppl step it up!
Old May 31, 2010 | 10:11 AM
  #1154
Frew's Avatar
lol, area I would dyno mine but it wouldnt be a straight comparision, since my last dyno I pullied down, ported head, throttle body, etc. It would be irrelevant.
Old Jun 1, 2010 | 07:18 AM
  #1155
Staged07SS's Avatar
Administrator
Administrator
Exactly !! I knew this would happen ....
Everyone has sat here talking about this header like it's going to provide some huge gain and be the best header for the LSJ, but there are no numbers to prove that. This is another reason why I don't take advice on mods from people on this site that often anymore. Most people say a certain product is better than another due to liking a particular vendor more than another. Rather than performing tests to see which product actually provides the best performance gains.
Old Jun 2, 2010 | 05:55 AM
  #1156
87gn06gto07irl's Avatar
How much extra would you want for one ceramic coated?
Old Jun 2, 2010 | 08:44 AM
  #1157
Josh@ottp's Avatar
We aren't offering that as an option. Your best bet is to get a quote from your local powder coat shop.
Old Jun 2, 2010 | 09:07 AM
  #1158
selfinfliction's Avatar
http://jetcoat.com
Old Jun 8, 2010 | 10:59 PM
  #1159
SSReepur's Avatar
I just installed my header and im liking it so far, it sounds nice and deep a little louder too.
Theres a sound of a leak somewhere i cant figure out where, i put my hands around the exits but dont feel anything, anyone else experience this?
Old Jun 8, 2010 | 11:00 PM
  #1160
ls1fbody's Avatar
Haz l33t wheelz.
Try the V-Band. Mine has a very slight leak until it get fully heated up, then it's fantastic
Old Jun 8, 2010 | 11:42 PM
  #1161
SSReepur's Avatar
Actually thats where i hear it and what do u mean by heat it up?
Old Jun 9, 2010 | 10:59 PM
  #1162
Greased's Avatar
once the metal expands it provides a better seal is what i think he is trying to say.
Old Jun 10, 2010 | 12:57 AM
  #1163
SSReepur's Avatar
Ahh I see, Its going away slowly im pretty sure it will go away, thanks guys
Old Jun 10, 2010 | 01:00 AM
  #1164
2MCHBoost's Avatar
It's Stainless. It doesn't need to be coated
Old Jun 10, 2010 | 04:39 AM
  #1165
HunterKiller89's Avatar
you dont coat headers for rust protection usually...
Old Jun 10, 2010 | 11:28 AM
  #1166
elecblue06's Avatar
the whole point of stainless is to not rust
Old Jun 10, 2010 | 11:32 AM
  #1167
spike's Avatar
idk if anyone here is from indiana but there is a place called Prokote that does a real go job at coatings. They are way cheaper then jet hot too. They are also a sponsor for IndyHP so you know its good stuff if you know IndyHP
Old Jun 10, 2010 | 08:52 PM
  #1168
im aware....i said coat, not use stainless steel.
Old Jun 13, 2010 | 10:58 AM
  #1169
Josh@ottp's Avatar
https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/longtube-header-3-cia-217402/
Header is on sale right now
Old Jun 15, 2010 | 10:52 AM
  #1170
ebristol's Avatar
You guys should bring one of these to CED. Have a buyer setup for a purchase and get them to run their car on the dyno for a baseline. Then install the header and get back on the dnyo to figure out the gains.
I know that the true gains of the header won't be seen without proper tuning but it would be interesting at least.
Old Jun 15, 2010 | 01:36 PM
  #1171
NWAE Cobalt's Avatar
found a new way to install it...
if you have your subframe out so you can replace your motor for a spun rod bearing and valve tap, then just slip it up through the bottom
Old Jun 15, 2010 | 09:49 PM
  #1172
RooTBeeR's Avatar
Ah, GOOD THINKING! would be interesting to see!
Old Jun 15, 2010 | 10:05 PM
  #1173
stealthy1ss's Avatar
I would be willing to do this but I would need to have someone buy my ZZP midlength combo at the meet. I could run on the dyno with my stock mani and dp or my zzp midlength catless setup.
Old Jun 15, 2010 | 10:37 PM
  #1174
RooTBeeR's Avatar
stock vs. longtube
Old Jun 15, 2010 | 10:49 PM
  #1175
I am sure that Tom would let us use a lift in the garage to put it on. Lets work something out Josh. I'll send you a PM.
