Ottp with Meth
Ottp with Meth
So I am looking at getting the OTTP 1 kit along with a meth kit. I am hoping someone may be able to help me on picking a kit. When i go on the ott website, i see three different meth kits. Can someone give me a basic breakdown of each and what the differences/ pros,cons of each are? i appreciate it. Also this will be for a dd, not for track use really ever, maybe 1-2 a year
The only 2 good kits are the 2 devils own kits in my opinion. There is the standard and the progressive. You will want to get the standard kit. The only difference between the 2 is a controller that is pretty much worthless. Also if you need a tuner, which you WILL need to be tuned for meth, let me know. I am not to far away from bolingbrook and I have really reasonable prices.
The standard version is just as good as the progressive. Even sean and josh over at ottp will recommend the standard version. It's really not worth it to get the progressive. The only + to the progressive kit is the fact that you can adjust the start and full spray on the fly. But if you think about it...that's pretty much worthless lol. Go standard.
IMO snow performance / AIS are better kits. higher quality components (check valves, nozzles, wiring). The pumps are about the same.
I just haven't been satisfied with the quality of my Devils kit. OTT was great in sales and support, I def would recommend them, but just get a different brand.
do any of the kits come with a tank, or do i have to use the windshield resevoir no matter what?
also with the tune, wouldnt ottp be able to tune it for meth injection? i would get the meth all ready to go before i went with the ottp kit?
not sure what the devil's own comes with. i ordered the AIS stage1 trunk mount kit off of the AIS website. came with the tank, 250psi pump, both nozzles(one that comes with the kit that you choose the flow of, and another one that i bought), both vaccum and methanol lines, power line, ground line. everything. i didn't need to make any runs to the store. nothin.
and with the components. all the companies are using brass pieces now, all nozzles have internal filters, all the components within the companies are practically the same.
The devils own standard kit comes with everything you need minus a tank. You can buy a 1 gallon tank separately on ottp's website. Grab some extra hosing so you can trunk mount it and your set. It's going to be cheaper then AIS and just as efficient.
Basically. This is what you should do. Grab the ottp stage 1 kit, grab the standard devils own meth kit, grab a 1 gallon meth tank. Then once all of it is installed, I will come give you a sick tune. PM me for some pricing =D.
