OTTP With no heat exchanger
Would it be dangerous to run the OTTP stage 1 kit without an aftermarket heat exchanger?
I would put the H/E and dual pass right up next to that mod, like next in line.
Me personally, cooling will probably be the next thing for me and I am only gmstg2, going tvs hopefully within a year
just don't do back to back pulls...give it a break inbetween to let it cool downif u get on it give it a couple minutes of normal driving before u get on it hard again...i had this same problem i just waited to install an ordered a H/E my CX Racing one just got in today
like i said... once it hits 160, back off. Don't keep going or you could hurt the motor and such... I've been running it for about 2 months now without it... I beat it... it does heatsoak, so that is why I am getting the h/e, and possibly a tvs later
Nick your ready to go on the heat exchanger
Everyone is on the ball with what they said about letting the car cool down oin between runs and not beating on it back to back to back.
Helped me when i ran my 2.5" with no cooling for 6 months ( not recomeended)
If your going to do MULTIPLE back to back to back to back pulls then I would be worried, otherwise you will be fine. The only thing else that concerns me is your staging lane iat2's will be high also.
Just save up for some cooling mods and don't beat the **** outta the car until there on there haha.
edit: sean gets the post in just SECONDS before me lol.
Last edited by Zach06CobaltSC; 06-11-2009 at 03:11 PM. Reason: Automerged Doublepost
Will it hurt it not per say if you watch it and don't go at it too much...but it's summer...it will take but 1 run to heatsoak the hell out of it more than likely...I think you'll be happier with the end result if you take care of the cooling first THEN the power..
Sean, I will be getting it here soon. Thanks, And yeah everything has been good, except i have been getting P0300, misfire code once in a while... Let me know if there is a fix for that
I know 60lbs are known for that
everything is fine, it just i was crusing the highway, and then down shifted down to 3 and nailed it, blah, the engine shut down... P0300. I have a Areoforce. Other than that the kit is great, I am still debating about that killer chiller... PM me some info on a decent clutch that can handle a tvs.
alright cool. Thanks for all the input everyone. I have all the parts for a stage 2 with a 2.9 pulley but than i saw that the ottp stage 1 kit is now only 340 so i needed to investigate a little more. How much hp and psi gain is there with 60's and a 2.8 compared to 42.5's and a 2.9" pulley????
n20saturn
09-30-2015 12:26 AM
