Ottp stage 1
Ottp stage 1
SO IM ABOUT TO ORDER MY OTTP STAGE ONE, WHAT OPTIONS SHOULD I GET?
Belt Option:
Please List Your Mods :
Pulley Options:
Catalytic Converter On Vehicle:
Vehicle Model:
Vehicle Year:
Throttle Body Fitted On Vehicle:
Rev Limiter RPM:
PCM Core Charge:
Remove Torque Management:
THANKS
Belt Option:
Pulley Options:
Vehicle Model:
Vehicle Year:
Rev Limiter RPM:
PCM Core Charge:
THANKS
Belt Option:
Pulley Options:
Vehicle Model:
Vehicle Year:
Rev Limiter RPM:
PCM Core Charge:
THANKS
Belt Option:
Pulley Options:
Vehicle Model:
Vehicle Year:
Rev Limiter RPM:
PCM Core Charge:
THANKS
Stage 2 belt
2.8 pulley
Stock throttle body i would assume?
7200 Rev limiter
I would remove torque management.
the pcm core charge is they send u a pcm with the tune on it. you then get the crank relearn and the security relearn and ur car can run. then u send back ur old pcm and get refunded. or u can send them ur pcm and they throw the tune on it and send it back. its easiest way if u can live without ur car for a bit. or get the tune emailed to u but u need to know someone with hp tuners
so the pcm tune is just so i could drive my car?
because i need to drive my car its my daily driver.
is this kit hard at all to install?
and wat about the torque management?
wats that?
wats that?
remove torque management. from what i understand tq mngt reduces the torque when you shift so that your internals won't get beat on as hard when driving spirited. have the tune emailed to you and load it onto a thumb drive. then find somebody with hptuners and install the ottp stage 1 kit the same day you can have the tune loaded into your pcm. don't drive your car with the kit on and no tune. you need to have it all at the same time.
I think you need to do A LOT of reading on these forums before you order any mods for your car!
Torque management limits power in 1st gear to make the car easier to launch. It also increases the life of your clutch and possibly other drivetrain parts. (ie. Axles and transmission).
Go with...
2.8" pulley
60lb injectors
stage 2 belt
7200rpm limit
remove trq management
if u know someone with hp tuners...get ottp to send u a email, load it onto a usb stick and get someone with hp tuners to tune you....bring your kit with you and install it where they are. You can not drive with 2.8/60 and no tune...my car had a hard time starting up and then would stall in idle with no tune. Not saying i drove the car to get tuned but while on the dyno to get dyno tuned we wanted to see what it would do.
ask for a tuner in the regional section for of california, there is a guy named Shaun who tunes for $300 with free updates so its worth it
we got a good group of folks from OC area IE area and most of cali haha
i think the guy that tunes is in my friends, but if u go with the canned tune there are a few people with HP tuners and its 100 bucks to unlock it and upload the tune from ottp to your pcm
is that why on roll races i stay RIGHT next to ottp staged balts? come on dood. all motors react differently to every little thing done to the motor. rather a reflash or a cai. myself i have a zzp s2 with tq management... they just Alter it and don't totally remove it. i bet if you emailed ottp before purchasing they would be happy to alter it instead of removing it fully. ottp and zzp only want there customers to be happy and get what they ask for. just zzp offers it right off the bat or u can fully remove it.
"Torque abuse modes are modified to eliminate bog during WOT." they modify it to be on the safe side and provide same performance as if it wasn't there dood. Before I bought my s2 from zzp i talked to zoomer i believe about it. might of been turbo tim. he re-assured me its safer to run it with the altered tq management as opposed to just removing it fully.
make it 7100 and shift at 7k. u dont wanna float ur valves. and making it 7100 means you wont have to worry about hitting "taching" out. meaning bouncing off the rev limiter when u shift. which will screw ur run
Last edited by 06SS ALL DAY; Oct 23, 2009 at 11:11 AM. Reason: Automerged Doublepost
Safer to run, and More power are two different things.
I didnt say it would be safer to run without tq management.
