Ottp stage 1 mounts.
Old Jun 23, 2010 | 04:21 PM
Caligula's Avatar
Originally Posted by Bl4des
yeah you got stage 1 which is only one of the trans mount get the other to make it stage 2
Got it. It was late last night. I was tired.
Old Jun 23, 2010 | 04:30 PM
Omega_5's Avatar
FYI, if you feel you need a bit more than the stage 1's can handle, but don't want to upgrade to a stage 2... just go down to your dealership and spend the whopping $45 on an LNF rear mount.
It kind of turns the stage 1 into a stage 1.5. It's stiffer, but isolates the sound and vibes better than the Stage 2 mount.
Originally Posted by northvibe
you're welcome. I didnt do that and me and rallyracer used a freaking prybar to install the front mount then I talked to John powell and he informed me of that "trick"...sure enough
Funny thing is, it's not really a 'trick' at all... it's right in the GM service manuals.
John and I even stated, in that RLF thread back in the day, the exact excerpt from the service book.
Old Jun 23, 2010 | 04:33 PM
Caligula's Avatar
Can someone post the 'how to' on the ottp mount?
I know I have seen one before.
Old Jun 23, 2010 | 04:36 PM
05Slowline's Avatar
^ look at this guy thinkin he runs **** . jaykaaa hahaha
what do you mean. you jack the car up on stands. then jack up on the tranny with a wood block inbetween just a little then unbolt the 3 bolts on the rear and theres 1 going through it..then the front one has 3 i believe 1 going through the middle. and loosen the passenger mount like said. oh and u gotta push the one sensor out of the hole on the rear mount then put it back in (biggest pita of this).
Last edited by 05Slowline; Jun 23, 2010 at 04:36 PM. Reason: Automerged Doublepost
Old Jun 23, 2010 | 04:38 PM
Caligula's Avatar
I just like pictures?
Found it.
https://www.cobaltss.net/forums/how-guide-43/how-install-ottp-rotated-mount-stage-1-a-154615/
Old Jun 23, 2010 | 04:40 PM
Omega_5's Avatar
I may have done a tour on another forum...
Old Jun 23, 2010 | 04:43 PM
05Slowline's Avatar
Oh. One of THOSE kids. .
orly .
Old Jun 23, 2010 | 04:47 PM
northvibe's Avatar
haha thats why I quoted the word trick. But I have never read the manuals, John just told me to do that.
Old Jun 23, 2010 | 04:56 PM
Dr.Balt407's Avatar
im going to the track friday with the stage 1 mounts for the first time. ill let you kno how they treat me
Old Jun 23, 2010 | 07:20 PM
Caligula's Avatar
Yeah, that would be good. Mine wont ship till the 25th, so any info would be good before I go thru the trouble of putting them on right away.
Old Jun 25, 2010 | 12:33 AM
  #36
Caligula's Avatar
Bump.
Will the ingalls help any along with the stage 1?
Old Jun 26, 2010 | 04:57 PM
  #37
Dr.Balt407's Avatar
soooooo i went to the track last night and the mounts worked very well but for the pwr im putting down my axle didnt do so well
stage 1 will do just fine for a street car and every now n' then to the track
pixs of destruction
http://www.youtube.com/watch?v=4h8IdcECwtk
Old Jun 27, 2010 | 12:18 AM
  #38
05Slowline's Avatar
Bump.
Ingalls is garbage.
pixs of destruction
and you sir. you get some 's. . I got stage ones sitting on my garage freezer lols.
Old Jun 27, 2010 | 12:22 AM
  #39
Caligula's Avatar
Dont you have like 400hp?
I think my car will be good. Thanks for the info.
Old Jul 7, 2010 | 08:08 PM
  #40
blackss2.0's Avatar
Does stage 1 also reduced engine movement enough so that I wont break any downpipes on hard shifts?
Old Jul 7, 2010 | 11:17 PM
  #41
05Slowline's Avatar
never broken a dp even on stock mounts
Old Jul 8, 2010 | 12:27 AM
  #42
blackss2.0's Avatar
Might have been because I hit **** with my down pipe like a really tall man hole and a speed bump that I didn't see. Not sure. But I read that the stock mounts allow the engine to move too much which sometimes causes the flex pipe to break and zzp even has a disclaimer pretty much saying its not their fault if you break one of there flex pipes if you don't have mounts.
Old Jul 8, 2010 | 02:51 AM
  #43
Dr.Balt407's Avatar
your right sir! i have a 2005 and with the stock mounts my engine wanted to hop out on hard pulls on top of that my flex pipe on the d/p cracked so bad my car sounded like a lawn mower for a month
after installing the mounts, shes as solid as a rock with no wheel hop
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
