Ottp stage 3 vs. Hahn turbo kit
OTT stage 3 kit...<400whp achievable. Hahn kit...over 400whp achievable on diff turbo.
Hahn's kit will cost you more in the end both on base price AND swapping turbo's if you wanna go for high hp.
Ott's kit will give you probably everything you want and more.
What it all comes down to is do you like turbo spool and smaller powerband or do you like blower whine and much larger powerband?
ill have my numbers in the next few days but on a bone stock motor with 2.6 ring, full exhaust, 3 inch intake and meth im anywhere from 350 to 370
im gettin on the rollers prolly within the week
it all depends on how hard u wanna push it..
I have no experience with meth
you kids and your TVS = superior powerband
a properly set up turbo set up on a 2.0L engine = superior to any supercharged variation
However in this scenario where the OP seems fairly new to modding I think the TVS provides a more simple bolt on solution with possibly fewer headaches.
personally I'd much prefer a turbo set up. you don't need E85 or ridiculous mixes of meth to get the power you want.
agreed that many turbos can provide good spool times and some good peak numbers.. but u will not find a turbo with the throttle response of a blower reving out to 7700..
smaller turbos are gonna lose their efficiency higher up ... the turbos that can spool to 10 grand are on supras.. but then theyre not spooling down low because they are 80 + mm
