overheating..stuck..help!
Old Nov 24, 2011 | 02:01 PM
SKCobalt's Avatar
x2... Turning on the heat in the car acts as a second rad.
To the OP, I would say that you had or are having fan issues. While moving on the highway, you for the most part have enough air flowing through the rad to keep the engine temps in the normal range. While stopped you do not have that flow and the fans should kick in when the coolant temp gets to the trigger temp for the fans. This is why you saw normal temps on the highway and high temps in the city. Believe me on this one, I drove a car for 5 years without a rad fan. You had to be pretty carefull and watch your gauges on hot days, but otherwise it was fine (it was mainly a winter car so the lack of fan wasn't a problem and it was more than just replacing a motor to fix). lol
Old Nov 24, 2011 | 02:13 PM
outtamymind's Avatar
Originally Posted by nhanson
it doesnt move it any faster...it just acts like a 2nd radiator
well regardless, i have updated info now thank you. but still it cools off the coolant
Old Nov 25, 2011 | 12:56 PM
Bika's Avatar
Fail Less.
I'm always around 170. unless I idle it for 10-20 minutes then the temp will touch 195, at which point I have the cooling fans kick on and it drops instantly down to 170-180. My car always ran cold. so do a few other ss/sc that I know. :-\ My LS runs 180-200 constantly though. go figure
Old Nov 25, 2011 | 03:03 PM
winning_blue's Avatar
got it back..apparently nothing is wrong. The CEL code is for running lean and the cold air intake. just recharged it so we'll see what happens next haha
Old Nov 25, 2011 | 03:19 PM
Micro's Avatar
Buildup of snow and ice on or before the radiator can prevent air from passing through the cooling-fins. If there has been lots of snow or slush on the roads, make sure that the air passages on the front of your car are free of snow and/or ice.
My mom lost an engine in her Acura because of this very issue causing overheating.
Old Nov 25, 2011 | 05:24 PM
mrbelvedere's Avatar
Its not normal if your on the freeway...but if your stop and go or beating on the car then its normal
i once saw 225 after being hard on it (was actuallly 220 when i shut it off)
your temps in stop and go yea 200 to 220 but if you are out beating on it the temps should not get that high
Old Nov 25, 2011 | 08:34 PM
got it back, recharged the k&n and the CEL is gone...glad I know temps that high in stop and go traffic are fine though
Old Nov 25, 2011 | 09:57 PM
be carefull abolut how much oil you use onthe filter it will mess with the maf
Old Nov 26, 2011 | 12:21 PM
insylem's Avatar
My thoughts too,
^I Agree with this guy^
Check your fans.
If your T-stad was the malfunction, highway speeds would still be overheating.
Old Feb 1, 2012 | 11:34 PM
turbosmart4's Avatar
why do some cobalts run cooler while others are burning hot?...............
