p0171
Old Dec 12, 2008 | 05:07 PM
kristen's Avatar
p0171
ok well pulling code 0171.....i read what the code was but my ? to you is...where do i start?it's a 06 ss/sc this is my beater car so it's totally stock. the code came on today on my ride home. it seems to be running ok. the boost seems a little low when i hit the gas. not sure if that has ne thing to do with it.
the past few days it has been raining pretty wicked in pa. the car has been out alot.
Old Dec 12, 2008 | 05:14 PM
invisible's Avatar
How many miles to you have on it?
I believe that is a lean code.
Edit: nevermind. Reading > Me. lol
I would maybe try cleaning your MAF sensor.
Old Dec 12, 2008 | 05:28 PM
bamaboy22's Avatar
any fuel cleaner or injector cleaner used lately?
Old Dec 12, 2008 | 05:40 PM
Hockeyman's Avatar
If it's totally stock, take it to the dealer. It's a lean code probably caused by a leak in your plastic intake piping or a dirty/bad MAF sensor.
Old Dec 12, 2008 | 06:35 PM
kristen's Avatar
i'll try to clean the maf tomorrow.
Old Dec 15, 2008 | 09:42 AM
kristen's Avatar
tryed to clean out the maf, nothing has changed.
i havn't used any fuel injec. cleaner.
47k miles on the car.
what should i do next.
also seem like i have a whisle comin from the engine bay.
WHAT NEXT????
Old Dec 15, 2008 | 11:27 AM
OriGinaL Condo's Avatar
Still under warranty so hit up the dealer
Old Dec 15, 2008 | 11:30 AM
Psykostevo's Avatar
WHAT NEXT????
Sounds like an air leak. Take it to the dealer. You still fall under Powertrain Warranty.
Old Dec 15, 2008 | 09:59 PM
darkcavi's Avatar
p0171 is lean code and sounds like you have vacuum leak. we had one come in the shop today for the same concern and the cause of the p0171 was a split hose.
Old Dec 15, 2008 | 10:00 PM
Tank07's Avatar
u get a stage II........my friend started throwing that code after installing his cold air intake and then his stage II....
Old Dec 16, 2008 | 02:28 AM
krazycobalt's Avatar
If you read what he posted it says he is completly stock reading > you
Old Dec 16, 2008 | 06:37 AM
Tank07's Avatar
^^^my bad but my friend threw the same code thats all im saying
Old Dec 16, 2008 | 07:05 AM
kristen's Avatar
well i guess i still have lady luck on my side....on my way to work...the light went out. guess cleaning the maf worked just needed some time to reset! *knock on wood* lets know it stays off
thanks for your help
Dustonian131
Sep 23, 2015 08:03 PM
The Punisher
Feb 11, 2008 07:13 PM
o3nisoaso3
Jan 22, 2008 05:15 PM
Vin
Jun 7, 2007 06:45 PM
c24na
Tuning
Feb 11, 2007 01:00 AM
