P0171 Again
That looks like a 2.9 nate pulley to me, its hard to tell because the side ridges are much larger on the S2. Only way to really tell is to calculate out the diameter differences from measuring the circumfrences or using a fat micrometer.
i ordered it from nate and i got the pulley and bolts...but cars kinda down now,so it doesnt really matter anymore
please tell me your not rockin the NGK spark plugs.... also, I really won't recommend using a 2.9 on Stage 2. I know most people with disagree but I've not run across anyone who has it on there for more then half a year without taking it off. Check your SIP sensor on the blower, something tells me it could be off.
dude get the dam reflash from gm its not the "latest update for s2" its a different reflash i had the same codes over and over again and found out from the dealership that WE HAVE 7 UPGRADES that the only way to fix it so go there and ask them to put ur car on there tech 2 tool
****, i have one of the first S2 tunes on the market and i'm still running good (never reflashed) running 2.9" and NGK copper 1 steppers. Only p0171 code was from a stock folded coupler on my intake tubing on the underside where i couldn't see for months after doing my airbox mod. I was going crazy til i switched to an ebay CAI and found the problem.
oh yeah, and it ran like a bitch with that code, i bought a scan gauge because of it.
something isn't adding up the s2 reflash isn't the same the s2 reflash u had to buy in a kit the reflash im talking about is from gm to fix the little problems our cars have sorry but there wrong
Another UPdate..
Got car from dealer and i have 2 codes..p0300 random misfire and p0171 running lean..they checked everything that was possible and it cleared the codes,but later in the day it turned on again..only thing left to do was put back the s2 pulley and see wat happens
i pulled these two codes too... but i am a stock 2.2L
well atleast stock as in no power adders (intake, exhaust, turbo, s/c, none of that)
the codes been on for months and i havent found a way to get rid of them. need emissions test this thursday and need help!!!
just go to dealer and tell them to erase the code and it will never come back again
the p0300 is a spark plug problem..do to the dealer and get some stock plugs,and the p0171 is a problem the dealer will take cpl of months to fix,and eventually will never fix it..just request to get them bother deleted,but ur responsible if anything happens after that...
well wat i did is i put the s2 pulley back on and drove the car around for about 100 miles...car feels stronger with the s2 pulley vs the 2.9,somethings tellin me that the 2.9 pulley that nate sent me isnt a
2.9..its prolly smaller and im maxing out the injecotors since ive had fuel cut with that pulley..
here's a comparison..supposly 2.9 vs s2 pulley
Lets say the total diameter is D and the distance from the outside ridge to the top of the ribs where the belt rides is S
D - 2*S = pulley size, which I assure you is 2.9 in your case.
Nate
if i put stock ss/sc injectors in... the 32lb ones would i run richer or leaner???
and would that maybe help my p0171 code... i just failed the ****** retest again but i got the inspection passsed so now i got 20 days for this and p0300 code to clear but im pretty sure 0300 is gone
help???
help???
Last edited by o3nisoaso3; Dec 22, 2007 at 03:50 PM. Reason: Automerged Doublepost
