P0171 code "Bank 1 system too lean"
Old 11-09-2013, 01:56 PM
07sleeper's Avatar
I am, yet another, with the dreaded P0171 CEL code. "Tune it out" seems to be a general answer. However, I've seen many with this code that actually had something needing to be fixed/cleaned/replaced. So, I'm going through all options. If anyone has any ideas as to what it could be, please feel free to chime in. I have had the "Torque" android app hooked up to it. Not sure if it's just reading wrong or what but, my f/t 1x2 (which I'm assuming is my LTFT) is reading 99.2% constant. The f/t 1x1 (assuming it's my STFT) is right around 0. With variations up to +-8. I bought both O2 sensors and a fuel filter as a first effort. If I'm able to fix it I will repost saying what the culprit was.
Old 11-09-2013, 02:36 PM
mrbelvedere's Avatar
try posting this in the correct section problems and service section
Old 11-09-2013, 07:34 PM
TStone's Avatar
clean throttle body
Old 11-11-2013, 11:33 PM
tyeo098's Avatar
Originally Posted by TStone
clean throttle body
+1
I used to get P1101 codes all the time whenever I turned the AC on.
Cleaned the throttle body with some walmart brand carb cleaner (remove it first! dont get that crap in the S/C) and no CEL's since
Old 11-12-2013, 01:51 AM
cole3883's Avatar
i used to get that code, dealer replaced my fuel pump and i havent seen the code again
Old 11-15-2013, 02:39 PM
Turbo6's Avatar
Have you tried taking the intake off and cleaning out the MAF with the spray cleaner? I need to do this on mine. But as they said, cleaning out the TB really good is a quick thing to try.
I've been having this code off and on for a year. I've tried different brands and grades of fuel. In winter I don't ever go WOT so I run 87. I've replaced O2 sensors and still lean bank 1. All I have done to my car is a cone filter airbox mod. Anyone know if a fuel filter could cause this?? I may change it just for giggles.
Old 11-17-2013, 11:01 AM
jcobaltss's Avatar
Do you have a tune for your air box mod?^ I know when I bought my car it had a intake, dp and exhaust and I'm guessing the person never had a tune on it and I was throwing the code for a while then I everyone said get a tune so I finally did and the code went away its been 4 months now.
Old 11-17-2013, 11:21 AM
Got Brakes?
Sox-Fan's Avatar
Air leak between MAF and throttle body?
Old 11-17-2013, 04:59 PM
sLAsh's Avatar
I don't know about anyone else's vacuum lines but mine are all dried out and cracking. I just got this code for the first time and that is where I'm going to start.
Old 11-18-2013, 11:25 AM
Turbo6's Avatar
jcobaltss, I didn't want to hijack his thread, but I do not have a tune for the airbox mod. UPS is delivering my header and downpipe today actually. And I'll be putting 60#s and a 2.8 pulley on as well so the tune will come after all that. I don't want to eliminate the codes (maybe the post-cat O2) that way I can actually tell if I have an issue.
To the OP, I replaced my silicon cracked hoses and that didn't help me. One thing you can try is getting a can of spray cleaner and spray around cracked hoses and intake clamp areas. If the engine can suck that cleaner into the intake the idle will stumble or surge. I went all around my IM, SC and intake and I had no leaks. It's a tune issue for me.
Old 11-18-2013, 02:48 PM
jcobaltss's Avatar
Would a broken flex pipe throw that code? I mean the stock dp are known to blow out but that's if he has stock dp. But everyone giving good info so it could be a lot of different things so just take time and check everything.
turbochargedss2012
09-20-2023 12:17 PM
01-12-2016 12:01 AM
patooyee
10-15-2015 05:11 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: P0171 code "Bank 1 system too lean"
