p0300
you did dual pass a few days ago didn't you?
vacuum leaks, go over every bolt you took off and make sure it's tight, that was my problem when I did mine, one screw somehow got overlooked just a little.
The cel would flash then go away and now only my interceptor will pick up the p0300 code.When i just cruise around the car is fine but when i get on it,it will bog down then take off then bog down again.
CobaltSS_25
Nov 17, 2009 05:20 PM
