p0315 and RAW intake with 3.5 inch throttle body
Old Apr 30, 2008 | 10:00 PM
z24turbo93's Avatar
I just got done installing a RAW stage one kit with 3.5 inch throttle body and RAW inake. I get code p0315 which from what i am reading is a CASE relearn that i need to do with a tech 2. (I have access to this so not a problem) But i have a question about the code and the intake...when i stab the throttle fairly hard while in neutral from what i call it a bark from the intake, but my father says its a misfire. Just wondering if this noise is because i need a CASE or just normal from RAW intake and 3.5in throttle body.
Old Apr 30, 2008 | 10:01 PM
BOOSSTED 06's Avatar
when i just had my intake before my exhaust was louder, when you just stab the throttle it barked as you would say, its the begining of the supercharger whine.
Old Apr 30, 2008 | 11:15 PM
LopsidedJester's Avatar
have you retuned the idle airflow ETC area scalar value to compensate for the larger throttle body?
Old Apr 30, 2008 | 11:36 PM
z24turbo93's Avatar
RAW tuned that all in for me. Idles perfect.
Old Apr 30, 2008 | 11:51 PM
ok, cool, didn't notice the RAW stage 1 in your sig. I wish my manual was here then i could look up p0315, know what it stands for? Could it be just a o2 sensor code being tripped that wasn't turned off?
Old May 1, 2008 | 12:42 AM
beercan's Avatar
You need a case re-learn man .. thats all it is
Old May 1, 2008 | 02:06 AM
Infernokron's Avatar
According to HP Tuners P0315 is "Crankshaft Position System Variation Not Learned". Not sure that helps any but there ya go.
Old May 1, 2008 | 06:39 AM
yeah you need a case re learn, just be careful not to flash you stock ecu with a stock tune when ya do it
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
