p0420 ??
Old Feb 19, 2011 | 06:28 PM
395 plus's Avatar
p0420 ??
I put a zzp catted dp on and get the 420 code a lot. If I disable the code through hptuners will the emission check that attaches to my OBDII port know I disable it or will it be just like not having the code at all??
Old Feb 19, 2011 | 06:59 PM
Dirty25RS's Avatar
I've been through this.
Here in ohio, with our emissions testing, they will detect the code being turned off.
The ECU has to be 'ready' for them to read it. If you've recently unplugged your battery for a long time, or had a dead battery for a long time, all those long and short term fuel trims are reset and they need to be relearned. Untill they stabilize, some bit in the ECU is set to "unready" and they cannot connect to OBD2 untill that bit flips to "ready"
If any code is disabled, the ECU wont become "ready" until that code is re-enabled. Now, here in Ohio, that doesn't mean you fail. It just means they have to do a sniff test. If you think you'll pass then you are good to go.
If not you may want to think about turning the code back on and buying a couple spark plug foulers, drilling one out, screwing them into each other and into the O2 bung, then screwing the rear O2 sensor into it. This will stop the P0420 codes even if its enabled, and you ecu will become "ready" again.
Old Feb 19, 2011 | 09:37 PM
shadowfaxss's Avatar
PA is the same except that you can have one readiness montior fail and still pass emissions. I had to reinstall my rear O2 to get the readiness monitors to set. All passed except cat effeciency.
Old Feb 19, 2011 | 11:24 PM
395 plus's Avatar
Do you mean these????
Old Feb 19, 2011 | 11:29 PM
dspeed123's Avatar
Disable the code. You will pass in WI.
Old Feb 19, 2011 | 11:37 PM
Dirty25RS's Avatar
pretty much yeah.
Old May 18, 2011 | 03:25 PM
BARBER_IMAZE's Avatar
would you pass visual with the foulers on it??
Old May 18, 2011 | 06:31 PM
Dirty25RS's Avatar
It was never a problem here in Ohio.
Old May 19, 2011 | 09:53 PM
Bornskinless's Avatar
Im glad theres no emission test in my county.
Old May 20, 2011 | 05:51 PM
^i hate you lol jk man. CA is so gay about emissions. I've looked all over for answers if it'll pass visual inspection here.
SSinPA
Jul 9, 2010 08:56 AM
SprChrg4Life
Jun 20, 2010 03:15 PM
XgunsmokeX
Aug 15, 2009 03:52 PM
jpunishment
Dec 11, 2007 10:48 PM
rollingboostedss
Jan 24, 2007 11:52 PM
