P0420 Code thrown, HPTuners fix?
I've been reading about the few codes that are often thrown in my cobalt. p0420 and the other one which is saying the system is too lean. I normally just go to autozone and get them to clear it for me, but its kind of a hassle. Looking for a more permanent fix. The hptuners stuff is like $500, what would be the cheapest alternative to doing that way? Anyone in lubbock tx that wouldn't mind helping a fellow cobalt owner out
. Someone was telling me that if you do a o2 spoofer, it actually can cause problems since the mixture of the fuel is based on the readings the o2 sensor gives.
Any advice? Is it possible to rent hptuners stuff?
. Someone was telling me that if you do a o2 spoofer, it actually can cause problems since the mixture of the fuel is based on the readings the o2 sensor gives.Any advice? Is it possible to rent hptuners stuff?
Just use an O2 sensor extender or whatever they call them to cure that P0420 code. As for the lean code, it happens sometimes on modded LSJ's, not really anything to worry about unless it happens all the time. Check for vacuum leaks or something like that if it is present at all times.
Thanks for the advice joe. Unfortunately the code has been going off for the lean system pretty much when ever the p0420 code is thrown. What is the best way to check for leaks? I really don't have much experience working with cars. ; / I though A/F mixture problems would be more based on injectors? Doesn't the o2 sensor behind the cat adjust the fuel mixture in the engine?
I bet antifoulers would get rid of this, when I went to a highflow cat on my old GTP, I kept throwing this code, some spark plug antifoulers from Autozone and a 3/8" drill bit solved my problems... pretty cheap trick that works most of the time... you just "hollow" one of them out...find rear o2 sensor screws into your exhaust, remove it, screw the unhollow antifouler onto your exhaust, then the hollow one onto it, then the rear o2 sensor will thread onto the hollow antifouler, clear the code... and no more problems... if you have a "low efficiency bank" that will solve the problem most of the time, here are some pics:
Hollowed compared to unhollow
the top "threaded" part goes into your exhaust, the o2 sensor will thread into the Hollow part
Bottom View with the hollow part in view
makes no sense, works like a charm
the antifoulers cost like $4 at autozone
Yeah, thats all the 'O2 fooler' things are. They just space the sensor away from the pipe. When you take it out of the stream, you slow down the readings, making it pass the computers test of being different from the first one. Most of the time, they work like a charm.
if they don't work, an o2 extender won't, these work in the same way... But I am confident this will fix your problem
but I know an o2 sim was like $90 for my GTP, my route was less than $5
those are the exact ones Autozone sales... same brand, everything... Help! is the brand, they should have a whole section of this crap, those are the ones I used... other than those, you just need a 3/8" bit and a drill, and a vice helps hold it while you hollow it out
I don't know discovered this, I actually found out about it on a 350Z site, I googled the code I threw just trying to get lucky and find a fix, and i'll be damned there was one... Word has gotten out now, most car forums know about it, sure some did here, if not... I did my part in getting the word out
it will work, I haven't ever did it on a Cobalt, so I don't know the spacing involved or if it will actually fit, but as far as principle, it will work on ANY car... and most car boards now know about this, I actually found it on a 350Z board, it works for them, it works on GTP grand prixs(what I personally used it on), it works on GT Mustangs(which I have personally saw it work on), it works on Mustang Cobras(supercharged), and it works on 4th gen f-bodies.............. if it will fit under a Cobalt(which one guy here tried it and never came back so I assume it fixed his), it will work
