P0420 Code thrown, HPTuners fix?
Old Apr 25, 2009 | 02:53 PM
Zach06CobaltSC's Avatar
I have a great idea, get an interceptor gauge so you can clear you codes yourself and also watch your iat2's and knock =P.
Old Apr 26, 2009 | 11:33 PM
BCobaltSS's Avatar
well just installed this mod. I just have to clear the code tomorrow . Stay tuned to see if it works
Old Apr 27, 2009 | 11:11 AM
silverbullet08's Avatar
I have the plug extender on my car. i drilled out my cat cause it kept giving me problems. The extender fixed the catalytic deficiency code. I also had the lean code. It was the oring under cylinder 2 injector all shrunk up and missing half a side. Damn GM techs. I put all new orings in and it fixed the lean codes and cylinder misfire code i was having under hard boost. check it out
Old Apr 30, 2009 | 01:12 AM
Dmen SS's Avatar
Well i tried this and it doesnt work. Im still getting a p0420 code any other things to try??
Old Apr 30, 2009 | 01:13 AM
Tank07's Avatar
Originally Posted by Bl4des
then lean code is most likely from your air box mod
very very true.......my brothers HHR through this same code after his CAI install........and HIV on here with his 07 SC threw the same code right after his cold air intake.......i wouldnt worry about it
Old Apr 30, 2009 | 02:35 AM
08inBama's Avatar
you sure everything is right? this is pretty much universal to any car, and it works on C6 Vettes, G8 GTs, etc... I don't see why it wouldn't on the Cobalt, I haven't personally used it on my Cobalt, but I have on previous cars
Old May 1, 2009 | 12:40 AM
Dmen SS's Avatar
I tried erasing the code again...Ill post if it comes back on. Its pretty easy 2 do
Old May 1, 2009 | 03:26 AM
joescobaltss's Avatar
i know my code keeps popping up as well but ima take it off and check everything out again my hole wasnt drilled to 3/8 does that make a difference
Old May 1, 2009 | 03:52 AM
08inBama's Avatar
there needs to be no "restriction" where the two pieces connect
Old May 4, 2009 | 12:25 PM
Dmen SS's Avatar
Well i drilled it out and everything...I get about 30 miles and the light comes back on
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
Adecker
Oct 20, 2015 09:46 PM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
