P068 engine power reduced
Old Nov 7, 2009 | 11:29 AM
advise's Avatar
so this happened to me three times and all of them where when i WOT shifted, the car misfires and has a lack of power and the the engine light flashes. Pulled over and was idling ruff as **** so i reset the computer by disconnecting the battery and started right up no problem,I think my WOT box went bad or something
bump help please
Old Nov 7, 2009 | 02:29 PM
Dennisscars's Avatar
Seems to do it at the most inopportune time generally between shifts at WFO. For me it's 3-4 redline shift when I'm passing a Porsche trying to make a point. Seems like it over MAF's and calls for the all stop.. if you leave the key off for about 3 minutes it'll reset itself. Runs like crap if you don't wait and seems to extend the time off.
I haven't found a cure yet but it seems to help if you don't slam shift.
Old Nov 7, 2009 | 02:53 PM
advise's Avatar
do you have a wot box
Old Nov 7, 2009 | 03:03 PM
Karlen89's Avatar
Mine did it when I had a wire to the maf go bad.
Old Nov 7, 2009 | 03:28 PM
advise's Avatar
ya but i dont understand what coulds be wrong if i reset the code and its fine
maybe it has something to do with my intake or a dirty maf ill check it out
Old Nov 7, 2009 | 03:39 PM
No, no box. My guess is that it'll over shoot the expected MAF value when you speed shift with a smaller pulley, wet the bed and call for the "oh crap something is wrong" mode..
Had the same issue with a blown LS6..
Old Nov 7, 2009 | 03:45 PM
advise's Avatar
dont know much about tuning but is it possible to fix that
Old Nov 7, 2009 | 03:53 PM
The guy that tuned my LS6 did, haven't been able to on the LSJ.. yet..
I've had to learn how to not speed shift..
Old Nov 7, 2009 | 05:09 PM
Bika's Avatar
Fail Less.
disable the code. set it to 8000rpm enable. the 07 ss/sc had this disabled from the factory.
Old Nov 7, 2009 | 05:25 PM
advise's Avatar
any idea what its set to on an 06
Old Nov 8, 2009 | 12:48 AM
Bika's Avatar
Fail Less.
800 rpm
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
